Ghost in the seat
Tonym3
Mazda CX5 GT
I am having trouble with my driver's seat randomly resetting. I t doesn't matter how many times I reset it to memory, or just move it forward, it keeps reverting to fully back on its slides. It is dangerous when I am driving. I have checked connections and searched for anything that could be causing it, even pulled the switch apart (and putting it back together) didn't help. Suggestions please.
Wait... does this happen when you're driving? If so, this is definitely a safety problem and you need to go back to the dealer ASAP!
Otherwise, does your key fob memory setting have the seat all the way back? If so, you may be accidentally pressing the key fob button in your pocket.
Set it where you like and pull the fuse ? 🤔 How often do you change the seat's position ?
While driving is a major issue that is not normal operation.
Otherwise I was going to suggest it might be happening as intended with a key fob unlock which you can set a position to (Set position, press Set, then unlock button on the fob).
