- Denver, CO
That's a great idea.I'm a raybestos fan (the element3 series with the coated rotors) maybe save the ones you pulled off to get them machined for the next time if it doesn't cost too much.
Honestly I think I will take @HyFlyer's advice and just keep the Bosch rotors around and get them resurfaced for the next time and then can switch them.I would find someone to resurface your rotors first, see if that even does anything.
So that's two votes for the Element 3's then. Nice.You need a special gauge to measure run-out on something like rotors. Good thing you verified there wasn’t visible build up on them, won’t be able to see warping if present.
Technically you might be able to find a place that could turn the rotors while they’re on the car, but I’d personally start over. I’ll second the element 3’s. I only have 2k miles of experience with them on my Titan but they’re great. Stops well going downhill while towing 5k pounds. Will likely choose them again for the CX-5 and RAV4 when the time comes (barring no issues on the truck lol).
I thought the Akebono Proact pads were just fine too (I used those on my old ‘13 CX-5). I don’t think you’ll go wrong either way. I thought the same thing as you too on the hybrid pad. The truck had ceramics from the factory, the previous owner I think had some Brakes Plus cheapo pads put on, and when I purchased I had to get rid of the shudder issue. Supposedly the hybrid pads have a little more bite for towing so I’m a happy camper (no pun intended).So that's two votes for the Element 3's then. Nice.
I was thinking Akebono pads, but saw mixed reactions. I thought they were the OE for Mazda so figured safe bet. Then saw the Element 3's were a hybrid ceramic / semi-metallic so figured that would be an upgrade to the stopping power over just ceramics, so definitely leaning that way.
I remember reading (during my brake pad research) that those dust a lot.I'm a raybestos fan (the element3 series with the coated rotors) maybe save the ones you pulled off to get them machined for the next time if it doesn't cost too much.
My Akebono ProACT ceramic pads will still trigger ABS even with tires far better than what comes on the car. So I don't think you'll reduce stopping distances with any brake pad upgrade.So that's two votes for the Element 3's then. Nice.
The Element 3 EHT actually don't generate that much dust. More then OEM but nothing like the old semi metallic. I'll gladly take the increased dusting to gain better braking over the OEM. I've mentioned before about my dissatisfaction with Proacts. It's like the Proact mantra gets repeated and that's why I tried them. Although I haven't tried too many full ceramics, I haven't been impressed with any, Mazda included. The Element 3 EHT are really about the minimum braking grip that I want. The coefficient of friction codes for the front pads are GG (vs FF OEM) and GH for the rear.I remember reading (during my brake pad research) that those dust a lot.
If considering the Element 3 EHT (EHT--hybrid, not plain Element 3 full ceramic), you may want to get them sooner than later because the parent company for Raybestos has filed for bankruptcy which may cause supply issues. Try Rockauto, maybe Amazon-- I got good prices from both.So that's two votes for the Element 3's then. Nice.
