- Denver, CO
That's a great idea.I'm a raybestos fan (the element3 series with the coated rotors) maybe save the ones you pulled off to get them machined for the next time if it doesn't cost too much.
Honestly I think I will take @HyFlyer's advice and just keep the Bosch rotors around and get them resurfaced for the next time and then can switch them.I would find someone to resurface your rotors first, see if that even does anything.
So that's two votes for the Element 3's then. Nice.You need a special gauge to measure run-out on something like rotors. Good thing you verified there wasn’t visible build up on them, won’t be able to see warping if present.
Technically you might be able to find a place that could turn the rotors while they’re on the car, but I’d personally start over. I’ll second the element 3’s. I only have 2k miles of experience with them on my Titan but they’re great. Stops well going downhill while towing 5k pounds. Will likely choose them again for the CX-5 and RAV4 when the time comes (barring no issues on the truck lol).
I thought the Akebono Proact pads were just fine too (I used those on my old ‘13 CX-5). I don’t think you’ll go wrong either way. I thought the same thing as you too on the hybrid pad. The truck had ceramics from the factory, the previous owner I think had some Brakes Plus cheapo pads put on, and when I purchased I had to get rid of the shudder issue. Supposedly the hybrid pads have a little more bite for towing so I’m a happy camper (no pun intended).So that's two votes for the Element 3's then. Nice.
I was thinking Akebono pads, but saw mixed reactions. I thought they were the OE for Mazda so figured safe bet. Then saw the Element 3's were a hybrid ceramic / semi-metallic so figured that would be an upgrade to the stopping power over just ceramics, so definitely leaning that way.
I remember reading (during my brake pad research) that those dust a lot.I'm a raybestos fan (the element3 series with the coated rotors) maybe save the ones you pulled off to get them machined for the next time if it doesn't cost too much.
My Akebono ProACT ceramic pads will still trigger ABS even with tires far better than what comes on the car. So I don't think you'll reduce stopping distances with any brake pad upgrade.So that's two votes for the Element 3's then. Nice.
The Element 3 EHT actually don't generate that much dust. More then OEM but nothing like the old semi metallic. I'll gladly take the increased dusting to gain better braking over the OEM. I've mentioned before about my dissatisfaction with Proacts. It's like the Proact mantra gets repeated and that's why I tried them. Although I haven't tried too many full ceramics, I haven't been impressed with any, Mazda included. The Element 3 EHT are really about the minimum braking grip that I want. The coefficient of friction codes for the front pads are GG (vs FF OEM) and GH for the rear.I remember reading (during my brake pad research) that those dust a lot.
If considering the Element 3 EHT (EHT--hybrid, not plain Element 3 full ceramic), you may want to get them sooner than later because the parent company for Raybestos has filed for bankruptcy which may cause supply issues. Try Rockauto, maybe Amazon-- I got good prices from both.So that's two votes for the Element 3's then. Nice.
That is all I needed to seeMore then OEM
I don't have an answer about our different experiences with the Proacts in cold weather except that they were on my previous car. Regarding dusting, I was amazed about the essentially no dusting when I bought my CX-5. Just a small amount of light gray that blended in with the silver wheels. Basically not noticeable.That is all I needed to see
Had a lot of dust from the OEM pads.
Regarding the cold weather comments, I have driven my ProACTs through 0°F weather recently. No issues, didn't have to brake any harder than usual.
Brake dust on my 2023 Turbo was brown to reddish brown. The color of the pad material, basically.Just a small amount of light gray that blended in with the silver wheels.
You’ll have to paint the calipers to achieve the full Brembo benefitThanks for the input all. Thinking I might try the Brembo rotors with the Element 3 pads. Thoughts?
The shipping is about $32. Not bad really, under $300 for everything.
I'm currently using Brembo pads with Brembo rotors, good combo, no dust, good stopping power, no noise.Thanks for the input all. Thinking I might try the Brembo rotors with the Element 3 pads. Thoughts?
Thanks for the feedback!I'm currently using Brembo pads with Brembo rotors, good combo, no dust, good stopping power, no noise.
Ever been to a scrapyard? Curious what the payout would be for the old rotors. If you’ve never been it’s kind of a hilarious experience. I got about $20 if I remember right scrapping my old shocks and struts. Weighed my car going in and out to determine how much scrap I dropped off, drove around piles of torn metal to get where they wanted me to dump them.Thanks for the feedback!
I went ahead and ordered the Raybestos pads with the Brembo rotors, fronts and rears. 3 Tracking numbers lol. But $300 out the door which isn't bad.
