Geoffsurfs
- MSP 03
I need help on what wire to splice into for the light?
Thanks
Thanks
splitvizion said:can someone list the things that are wrong off the floor with this car. Like I said I am about to buy and would like to throw a couple things in there face at the dealership for price lowering. I have them at about 18,500 with everything out the door and them paying for my taxes as of now. I am buying it in a differant state. Do you think this is a good price. I've heard 16,000 by some people on sites. That sounds a little extreme seeing that the listed price everywhere on the web is 20,500. And Invoice is listed at 18,750. Finally, does anyone regret buying this car for any reason. Thanks.
Herejonnydoe48 said:mm where did you guys put the grounding wire?
ground it on steering wheel columnjonnydoe48 said:mm where did you guys put the grounding wire?
Yeah, it's blue with a red stripe. I found it using a testlight and turning the fogs on and off a few times.Geoffsurfs said:hey tease, the wire i want for the fog light is blue with red striping on it? Thanks for the pics, i just want to make sure i am reading it correctly before i go cut wires.
Out of curiosity, how did you figure it out?
That's exactly why I wanted mine hooked up the the fog relay. There are times around here when I want the guage on. Then, there are other times when I want to be left alone and for a more "stealthy" appearance, I can turn the foglights off which loses a bit of the exterior sport car appearance and also turns the guage off. Plus, the guage dims out with your brights on. The way I see it, if I'm driving with brights on, it's because I need to pay attention to the road, so a blue light in my view only takes that much more attention off.Dr.Sound said:nope
wired it to the green-black wire on the dimmer switch.
dimmer switch is the first one so it's the easiest to get to.
question:
if u wire it to the fogs, wouldnt it mean that the guage will go off if the fogs are turned off?
i might be wrong on this.
