Argh Random Computer Freezes
i can hear my fan when it kicks in, but its not on right now.
I've NOTICED that it freezes more when running windows media player (more CPU intense?)
Processor
* 1.70GHz Mobile Intel Pentium 4 Processor-M
* 512KB on-die L2 cache; 400MHz system bus speed; 32-bit bus architecture
Memory
* 256MB on-board; one DIMM slot available to upgrade to 512MB total memory
Video
* 14.1"/15" XGA TFT display.
* Internal max: 1024 x 768 resolution, 16M colors.
* External max: 1600 x 1200 resolution, 16M colors
* ATI Mobility Radeon? with 8MB integrated video memory delivers unprecedented performance in 2D/3D graphics with AGP support
(Note: one configuration of C2010 which is sold through retail stores only has 8MB of video memory, product part number FPCM30533)
* Simultaneous support for external monitor and internal display
Storage
* 40GB, 30GB or 20GB ultra DMA 100 hard drive
* Built-in 3.5" 1.44MB floppy disk drive
* Built-in CD-ROM drive (24x max), DVD drive (8x max), or DVD/CD-RW combo drive (8x DVD/10x CD-RW/24x CD-ROM)
Audio
* SigmaTel STAC9767 with wavetable, 3D effect, and 3D positioning
* Dolby Headphone application simulates realistic surround sound using conventional stereo headphones while playing DVD movies
* 16 bit stereo audio
* Two built-in stereo speakers
* Optical digital (SPDIF) out/stereo line in
* Headphone, microphone jacks
* Volume control dial
LifeBook Application Panel
* Programmable application launch buttons for Internet, e-mail and two additional software applications
* Also functions as a CD player with "stop,""play,""forward," and "reverse" buttons
Communications
* Built-in multinational 56K V.90 modem
* Built-in 10/100 Base-Tx Ethernet
* Integrated Wi-Fi compliant wireless LAN (802.11b) - configurable option
User Interfaces
* Intelligent sroll button for easy navigation
* Full-size, 87-key keyboard with 19mm spacing and 3mm stroke
Interface Ports
* Four USB, IEEE 1394, S-video out, infrared (IrDA-compatible, 4 Mbps), enhanced parallel, external monitor, modem (RJ-11), Ethernet (RJ-45), audio line-in with optical digital out (shared)
PC Card Slots
* Two Type I/II or one Type III
* 32-bit PC CardBus architecture
Batteries
* Up to 3.0 hours4 of battery life
* Removable 9-cell Lithium ion battery; 10.8V 4500 mAh
AC Adapter
* Auto-sensing dual voltage support, AC100-240V
* DC 19V, 3.16A
Dimensions and Weight
* 14.1" model: 12.1"(w) x 10.6"(d) x 1.4/1.8"(h); Approximately 7 lbs
* 15" model: 12.8"(w) x 11.1"(d) x 1.4/1.8"(h); Approximately 7.3 lbs
Operating System
* Choice of Microsoft Windows XP Home, Windows XP Professional, or Windows 2000 Professional
Pre-installed Software
* Fujitsu Service Assistant, Adobe Acrobat Reader, Microsoft Works, Quicken 2002 New User Edition, Microsoft Internet Explorer, Netscape 6, EarthLink, MSN Explorer, McAfee.com VirusScan Free Trial, PowerQuest Drive Image Special Edition, Fujitsu BatteryAid/Hot Key Utility, and LifeBook Application Panel.
* Depending on your configuration, you may get Intervideo WinDVD and/or Easy Systems Drag'n Drop CD
Regulatory and Compliance
* Energy Star compliant
* Regulatory: FCC Class B, FCC part 68, UL approval
Warranty
* One-year International Limited Warranty5
* 24x7 technical support
* Fujitsu Premium Care Service Plans available
oops Kpa, ill let that disk run again 2nite. thx for the help. im downloading that link now.
i'm going to bet i need another fresh install of windows- it all started after i downloaded a crack. the crack never had any viruses or spyware, but its questionable. btw, the cracked program is uninstalled, yet the problem continues. so if anything, it hid in explrer.exe
you might as well.. I do it at least once a year... sometimes 3 times. its easy with 4 HD's
i'm leaning towards its windows, not the CPU. I just have been running some pretty heavy stuff, and the fan was really working hard. now its quiet since i've stopped those apps.
damn windows.
argh, now i have to backup my mail and all that s*** :(
damn windows.
believe me...it's worth the effort. there isn't that much like a fresh version of windows. its so fast. but then, as usual, it slows down in like 2-3 months
I just bought an external hd for my laptop so i can put everything on that and reinstall windows without much effort. very conveinent.
cant- school uses winxp. all my apps are winxp.
i would, but my crutial apps are winxp :(
like dreamweaver, etc.
SiSoftware Sandra
Benchmark Results
Dhrystone ALU : 4202 MIPS
Whetstone FPU : 1167 MFLOPS
Whetstone iSSE2 : 2096 MFLOPS
Performance Test Status
Run ID : PDEHAAN on Thursday, February 03, 2005 at 12:35:19 AM
NUMA Support : No
SMP Test : No
Total Test Threads : 1
Multi-Core Test : No
SMT Test : No
Dynamic MP/MT Load Balance : No
Processor Affinity : PP0
Number of Runs : 64000 / 640
Processor
Model : Intel(R) Pentium(R) 4 Mobile CPU 1.60GHz
Speed : 1.60GHz
Performance Rating : PR1755 (estimated)
Type : Mobile
L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector
Chipset 1
Model : Fujitsu Ltd 82845MZ Brookdale Mobile Host-Hub Interface Bridge (B1-step)
Front Side Bus Speed : 4x 100MHz (400MHz data rate)
Features
SSE2 Technology : Yes
SSE3 Technology : No
HTT - Hyper-Threading Technology : No
Performance Tips
Notice 5008 : To change benchmarks, click Options.
Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.
Notice 5006 : Only compare the results with ones obtained using the same version!
Warning 5009 : Mobile processors yield lower indexes in power management modes. Check power settings if index is low.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
SiSoftware Sandra
Benchmark Results
RAM Bandwidth Int Buff'd iSSE2 : 815 MB/s
RAM Bandwidth Float Buff'd iSSE2 : 816 MB/s
Int Buff'd iSSE2 (Integer STREAM) Results Breakdown
Assignment : 784MB/s
Scaling : 782MB/s
Addition : 849MB/s
Triad : 848MB/s
Data Item Size : 16 byte(s)
Buffering Used : Yes
Offset Displacement Used : Yes
Bandwidth Efficiency : 51% (estimated)
Float Buff'd iSSE2 (Float STREAM) Results Breakdown
Assignment : 785MB/s
Scaling : 785MB/s
Addition : 848MB/s
Triad : 847MB/s
Run ID : PDEHAAN on Thursday, February 03, 2005 at 12:37:19 AM
Memory Used by Test : 128MB
NUMA Support : No
SMP Test : No
SMT Test : No
Page Size : 4kB
Use Large Memory Pages : No
Chipset 1
Width : 64-bit
Maximum Bus Bandwidth : 3200MB/s (estimated)
Logical/Chipset 1 Memory Banks
Bank 0 : 128MB DDR-SDRAM 2.0-2-2-5 1CMD
Bank 1 : 128MB DDR-SDRAM 2.0-2-2-5 1CMD
Speed : 2x 100MHz (200MHz data rate)
Width : 64-bit
Maximum Memory Bus Bandwidth : 1600MB/s (estimated)
Features
(W)MMX Technology : Yes
SSE Technology : Yes
Performance Tips
Notice 5406 : System bandwidth appears memory limited. Attempt to use higher-performance memory.
