- 2001 Mazda MP3
SiSoftware Sandra
Benchmark Results
Integer x8 iSSE2 : 9668 it/s
Float x4 iSSE2 : 12425 it/s
Performance Test Status
Run ID : PDEHAAN on Thursday, February 03, 2005 at 12:38:39 AM
NUMA Support : No
SMP Test : No
Total Test Threads : 1
Multi-Core Test : No
SMT Test : No
Dynamic MP/MT Load Balance : No
Processor Affinity : PP0
Rendered Image Size : 640x480
Processor
Model : Intel(R) Pentium(R) 4 Mobile CPU 1.60GHz
Speed : 1.60GHz
Performance Rating : PR1755 (estimated)
Type : Mobile
L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector
Chipset 1
Model : Fujitsu Ltd 82845MZ Brookdale Mobile Host-Hub Interface Bridge (B1-step)
Front Side Bus Speed : 4x 100MHz (400MHz data rate)
Features
(W)MMX Technology : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SSE3 Technology : No
HTT - Hyper-Threading Technology : No
Performance Tips
Notice 5008 : To change benchmarks, click Options.
Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.
Notice 5006 : Only compare the results with ones obtained using the same version!
Warning 5009 : Mobile processors yield lower indexes in power management modes. Check power settings if index is low.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Benchmark Results
NUMA Support : No
SMP Test : No
SMT Test : No
Processor
Speed : 1.60GHz
Type : Mobile
Chipset 1
Features
Performance Tips
