Really bad news, I logged my drive home from work today and it appears to be back to its old 16:1 self. I turned down the resistance of the potentiometer on the O2 signal before I tucked it away yesterday. When I turned it to 20kohm last week, my O2 voltage went to 1.2V. I was afraid that 50% of 1.2V would read .6V to the PCM and it would start pulling fuel again. So I figured if I went back down to 14kohm, I would be safer as I had good logs with that resistance.
I didn't measure it though, I just turned one of the two 10k pots down all the way down then turned it a few turns back so I would be somewhere around 14k. I should have measured I guess.
It is also possible with all the jostling and cramming that I caused the connection to the pot to break and wedge up against the opposite wire creating a short and essentially 0ohm, which we know won't work.
Then I guess it is possible that the PCM has somehow figured out that the O2 voltage has been reduced and now compensating, although I find that very unlikely.
I am so upset I have to take it back out of the car now. I spent most of yesterday getting it all put back together nicely and now have to redo everything. Kind of feels like I got punched in the balls.
