- -- 23 CX-5 --
The rpm in sportauto is 3000 at 70mph....65 isn't much less, like 28-2900
Is the rev being at 3500 a cause for the decline in fuel economy?
yeah I hate that, really wish we had a 6th gear. Only flaw in the P5 imo65 is 3000 in a manual 75 is 3500
I've read/heard debates about filling gas to the brim. With knowing that you can't believe EVERYTHING you read on the forums/Internet, I'm going to be filling it to the brim just for a few times to get a good enough sample of what my MPGs are. My MPGs are off from tank to tank when I stop filling when the pump shuts off. I can't guarantee that I'll go to the same gas station and pump every single fill up so filling it to the brim is the best way to get some more accurate measurements.
Every time I fillup (generally at same station) and the pump cuts off I always get most, all, or a bit more than another gallon in slowly filling to brim. How soon it cuts off is going to depend on pump delivery pressure with it all bubblin up in the neck it causes. Brim is a much better reference point to tighten up calculations on IMO. Using the brim should leave you with less variables, mostly the accuracy of the pump calibration & your trip/odo accuracy. All you have left is trip mileage divided by gallons of next fillup to brim. The other variable is how different I may have driven that tank compared to the last tank. That is what should be averaged - all frwy vs city or mix, did I drive nice or do an autocross, was weather and terrain generally the same as my usual commute.
