Looks within normal boundaries to me. I personally wouldn't be concerned.
You should see my RX-8's drinking problem.
Check the oil once a month. Sometimes oil seems to evaporate a little in hot weather. I also think some of it goes through the PCV valve. I don't know that means anything's wrong with it unless you get a check engine light.Hello! Long time lurker here. I have a 2021 CX-9 Signature and absolutely love it! I'm currently @ 9000mi and the low oil warning light came on a few days ago, confirmed by the dipstick. I did my last oil change @ 5000mi and by my estimate the car consumed around 1qt of oil in the last 4000mi. I use KNN oil filter and Castrol Edge Max Performance 5w30. No blue smoke from the exhaust so I'm suspecting the PCV valve. Any thoughts?
Your service advisor is a giant BS artist and 99 percent of them don't know their a$$ from their elbow. " Still lubricating the seals and bearings?" LMFAO. It's hard to find ANY good tech, let alone the joke service advisors and techs at stealershops. Go to another one or search Google for a top rated indie shop and get an impartial opinion. Stealershops ALWAYS says everything is "normal". They are pre programmed robots with no brain.Just got the car back from the dealership. So apparently, as expected, the SA said it was normal for a turbocharged car to consume "a lot" of oil especially my engine was still new. "Still lubricating the seals and bearings" he said. He didn't seem so suprised when I told him about the low oil level warning light. They did a 10K service (oil change and inspection). I checked the oil level when I got home and it was right above the HIGH mark so obviously they put more than 5.1qts. I asked the SA when should I be concerned about oil consumption. He said when my car gets to a "high mileage" .
Anyway, looks like I'll just the oil level monthly and always keep some fresh 5W30 handy.
I have a turbocharged Mercedes CLA250 with 100K miles on it and doesn't burn a drop of oil. My 2021 CX-9 is officialy an OIL BURNER!
Yes the oil level was a tad above middle of the low/high indicators of the dipstick. It was the entire 5qt jug.
Glad I found this thread. I have a 2021 CX-9 Touring with 6300 miles on it, no oil changes yet. Oil level light just come on tonight. Was planning to have the first service done at the dealer in the next few weeks, but it looks like it’ll be ASAP now.
Thanks! I’ll be sure to mention this when I bring it in Monday afternoon. One more question - I was planning to top it up before bringing it in, as I’m not keen on driving around today low on oil, but would it better to bring it to them low?It's possible that it could be this issue: TSB 01-12/21
Thanks for the TSB. This means Mazda hasn’t figured out what happened to this oil burning issue on these 2021 2.5T’s. Keep in mind that the car manufacture’s guideline of “excessive oil consumption” which is considered having problem and needs to get fixed under warranty is to use 1 quart of oil per 1,000 miles.It's possible that it could be this issue: TSB 01-12/21
You’d want to leave the oil level alone to show the dealer the low oil level condition. Even the oil level is at Min / Add mark of the dipstick when you measured it the first thing in the morning before the engine start, the car is safe to drive at least for a short distance (20 ~ 100 miles?). If you’re really concerned, you can use free Mazda Roadside Assistance to tow your CX-9 to the dealership.Thanks! I’ll be sure to mention this when I bring it in Monday afternoon. One more question - I was planning to top it up before bringing it in, as I’m not keen on driving around today low on oil, but would it better to bring it to them low?
IMO these 2 (major) issues going on on the 2.5T shouldn’t be related, and any revisions to the cylinder head and exhaust gasket for coolant leak problem can’t cause any more oil consumption. Most likely this oil consumption issue is caused by a batch of inferior parts, such as the valve stem seals or piston rings, got introduced into the engine assembly line due to poor quality control.I wonder if this will effect those who ad their engines replaced from the coolant leak. Curious if they fixed one problem and now have another.
