2019 CX-5 Coolant problem (CEL = P0126)
Daughter's 2021 CX-5 had a check engine light. Dealership found code P0126 and TSB 01-23-04, her CX-5 will be repaired in 10 days and under warranty. I am just disappointed that from this thread, it a well known issue and Mazda has not properly addressed it. I could not find the TSB online, so I am not sure if they have a new part or not.
alright.. Verdict is in ... Mazda is going to cover 80% of the repair, which is about $600, so I will have to pay $120 out of pocket.. I'll take it. Not worth my time and energy to fight for the additional 20%. The rep also told me that had I gotten them to cover it 100% out of warranty, if the new part is defective, Mazda would not be responsible, so by having me pay the 20%, there is a warranty on the new part. Sounds strange. I know.
I still haven't received any information has to how the thermostat differs from the control valve..
A TSB has been issued and the coolant control valve is indeed covered under powertrain warranty instead of new car warranty as you’d been told by MNAO. So you may be able to ask for reimbursement from MNAO at this time.
TSB No. 01-005/23 Check Engine Light On with DTC P0126:00
My '22 with CD is now experiencing the exact same problem. Have to wait until Dec. 2 to get it looked at.
Another 2 recent cases here on newer 2021 / 2022 CX-5 2.5L NA with CD. Even though Mazda has been claiming in previous 2 TSBs since 4/22/2021: “To eliminate this concern, the production process of the coolant control valve has been modified.”, the coolant control valve problem seems to be persistent.
One problem I have had with my NA 2021 CX-5 is the electronic thermostat. The engine wasn’t coming up to temperature. The dealership dismissed it the first time I complained. They said it was throwing no codes. The problem persisted, so several months later, I complained again and the same dealership found the problem and replaced it under warranty. The thermostat isn’t a $12 part from NAPA that can be replaced in 20 minutes. The thermostat costs about $450 and probably requires 2+ hrs shop time to replace it. Not sure if the turbo version has the same thermostat or not. The failure of mine might have just been an outlier.
After a couple weeks of my '22 w/ CD being very slow to warm up to a normal temperature, today the Check Engine Light came on. Sure enough, it is code P0126 so I will be contacting the dealer to get this fixed. :(
Thank you, so you think I can get mazda to reimburst me from 3 years ago?
Definitely! Although your $120 paid in Jan. 2021 will have much less buying power right now due to high inflation in recent years.
OWNER NOTIFICATION
Mazda will notify all U.S. owners of the subject vehicles by first class mail no later than November 21, 2024.
• Owners will be advised that they do not need to bring their vehicle to a dealer if it does not exhibit the affected condition.
• Owners will also be advised that any previous repair on the fail-safe thermostat or coolant control valve due to similar concern of this SSP will be eligible for reimbursement if the repair was performed at the owner’s expense. Please refer the customer to the Owner Letter for reimbursement instructions.
Call MNAO to get instructions for reimbursement. Your Mazda should have all the documents for your repair if you’ve lost your invoice.
SSPD8 - Check Engine Light ON with DTC P0126:00
Mazda has issued a Special Service Program D4!(SSPD4) on this “Check Engine Light ON with DTC P0126:00” problem with the thermostat stuck open on the 2.5L NA with CD as posted above. The SSP stated the warranty coverage for specific repair of the “fail-safe thermostat” in the coolant control valve is extended to 15 years (180 months) or 150,000 miles (240,000 km) whichever comes first, from the original warranty start date.
Also, Mazda has introduced a replacement kit of the thermostat located within the coolant control valve (CCV). Now the “fail-safe thermostat” is available separately so that the replacement of expensive coolant control valve (part #: PYFD-15-16ZA, MSRP: $454.36) is no longer necessary, only the thermostat (PYY2-15-SA1, MSRP: $31.11) and connector / gaskets are needed.
Parts Flash Reference No: RF-24-09 *Update* Check Engine Light ON with DTC P0126:00
TSB No: 01-005/24:
Unfortunately this situation is complicated by the fact that there is also a mechanical thermostat integrated into this coolant control valve. And I cannot find documentation on the operation of the valve, so it's unclear to me what the functionality of the mechanical thermostat is in the overall design of the valve.
So it appears that this Mazda stealership is trying to say the mechanical thermostat would be covered, but the valve is not. I agree with what you're saying, however it seems, based on the OP's case that they are relying on technical semantics to bail out on this warranty coverage. Time will tell where this ends up, but I would personally test the thermostat, regardless of anything else, because IMO it's very important to determine if it's working properly or not.
Based on the latest TSB 01-005/24 you’re correct that there’s a mechanical thermostat which is built into the coolant control valve. Although it looks different from those we usually see and it certainly is different from those “electrical thermostats” been used on Toyota’s. Luckily Mazda has made a right decision to make this proprietary mechanical thermostat available for parts in case it fails, and extended the warranty of this thermostat in coolant control valve for a long period of time.
Mazda has lost my trust and a customer of over 42 years, due to their handling of this issue.
They recovered from the "black eye" caused by oil consumption on the early rotary engines.
But, instead of learning from that and stepping up to the plate as Honda and Toyota have done many times, they chose to try sweeping it under the carpet.
Interestingly, I have received ZERO response from them on the MANY efforts to contact Mazda North America and Mazda Japan ( I have a relative fluent in Japanese that wrote the letters).
The current fix I suspect is another BAND-AID like the others before it. Being an engineer with a strong Automotive background their attempts to tightly control engine temperatures with an electronic valve FAILED MISERABLY and REPEATEDLY. I do not know the impact this may have on emission components, testing or motor longevity. But I no longer own a MAZDA and never will again 👎. During my career I worked with and for more than one Japanese company. This blundering fiasco would not have been tolerated in those companies. Possibly they need to learn what Detroit did in the late 70's
To be fair, many car manufactures will fail on customer satisfactory category from time to time, with different reasons. I used to buy VW only until they refused to fix the severe oil consumption problem (1 quart oil per 800 ~ 1,000 miles) on my 2001.5 Passat GLX 2.8L V6 5-speed under new car warranty. Needless to say I’d never bought another VW since then.
This coolant control valve problem of yours must be considered as non-critical problem by Mazda, or Mazda didn’t have any good solution at the time. Mazda eventually did a right thing with a long warranty extension, and came up a much cheaper thermostat kit only to fix the problem.
Not surprised that Mazda didn’t do the right thing on customer satisfactory category.
Firstly, the thermostat inside the coolant control valve isn’t an “electric thermostat”, but a traditional mechanical thermostat with different size. Not sure why Mazda would fail to manufacture a good old thermostat properly, as those related TSBs since 4/22/2021 keep saying: “To eliminate this concern, the production process of the coolant control valve has been modified”, but the coolant control valve problem seems to be persistent.
By comparison, the newly added “electric thermostat” (not to be confused with Mazda’s “coolant control valve” although they both can have much more precise coolant flow control for different engine temperature) on Toyota’s Dynamic Force high-compression 2.5L / 2.0L NA found on my daughter’s 2022 Corolla Hatchback XSE doesn’t seem to have any issues since 2018!
You must missed many scandals happened from many major car manufactures in Japan recently. Their car industry is having problems IMO.
Back in 2018 I was planning to get a new 2018 CX-5 but immediately dropped the plan once I learned Mazda had added cylinder deactivation to a reliable 2.5L NA. Why Mazda spent that much effort and money to a feature which is historically having the bad reputation of failure, and gained 0 ~ 1 EPA fuel consumption ratings on an already efficient 4-cylinder engine? Looking back, almost EVERY component Mazda modified to accommodate cylindef deactivation has problems! Rocker arms / switchable hydraulic lift adjusters、cylinder head、transmission / torque converter、now the coolant control valve. In addition to bad decision making, it’s an indication of lack of good design on quality when Mazda engineers are redesigning something or doing the modification on parts. IMO Mazda’s R&D department seems to have some major problems in recent years.
There is A lot more to the story than what I posted.
The reason for the Electronic control valve was to regulate engine operating temperatures more tightly than possible with a mechanical thermostat. This allowed higher compression ratios, lower emissions, more power and better MPG.
According to available information, the first reported recall on a Mazda CX-5 related to the coolant control valve was likely issued for model years 2014-2016, with the issue being a potential malfunction in the failsafe thermostat within the coolant control valve, which could lead to unintended opening at lower temperatures causing engine temperature concerns; this recall was addressed by replacing the coolant control valve with a modified version.
So I must ask, how many iterations and years does it require to FIX the problem?
Their design was flawed as were their attempts at "fixes".
my wife's vehicle had 7800 miles on it, about 1 year old and they said to drive it. I am not comfortable nor was she driving a vehicle around with the CHECK ENGINE Light on ALL the time.
What happens when another problem like a loss of oil pressure? DRIVE IT 👎💥. Not gonna happen nor will I subject her to that.
I went so far as to try to trade it in and an identical CX-5. They offered 12K saying they did not want it sitting on the back lot until parts became available.
Parts are available to build and sell new cars, why are they not available for the ones you've already sold???
If it is safe to drive then put it in your loaner fleet. Response, We can't have customer driving a loaner with the check engine light on..
EXCUSE ME! But WTH am I?
I'll disagree as a motor running cold uses more fuel, emits more emissions, can lead to carbon build up in the combustion chambers, fouled emissions components, diluted oil & premature engine wear as a start.
How long has this "FIX" been tested? Likely as long as the previous attempts.
Also, it remains to be seen just how far Mazda will go if and when the above issues surface. Based on this example I would not trust them to stand behind much. I see their Extension as nothing more than what bulls leave behind them.
One of MANY examples
Again we differ as I was. It took HOURS on hold (literally) to reach their customer service people. One actually said she would hang up if II didn't like what she was saying. Not one of them I reached seemed to care. Worse than Peg Bundy with a new box of chocolates and a new soap opera. If you were disconnected, Sorry, start over.
I apologize for my iniquitous error on the terminology used "electric thermostat". I'll take 50 lashes with a ford serpentine belt.🤣
Persistent was a blatant euphemism and another attempt to bring the bull around again.
My point exactly on the Toyota
I'm guessing so 🤝
I'll agree and say that I've noted this with a few other offerings from Japan. The total lack of response or caring was shocking to me. As previously mentioned I have worked with and for Japanese companies in technical/ engineering capacities. This behavior would not have been acceptable or tolerated.
I am beginning to believe the root cause is the current generation has not suffered the hardships of their predecessors. Much like the 2nd generation of WWII Americans that led us into the late 70's early 80's when the quality of American goods tanked. We becamae complacent and lazy. Japan was ready. History may just be about to repeat itself. Who will it be? China appears to be a front runner but there are others 🤔
The saddest part is MAZDA WAS our go to for many years. I would buy 2 new 83-85 626's if possible. That was my all time favorite newly purchased car, and I have owned MANY new cars.
SAD 😥
Have to make a correction here that Mazda didn’t use “coolant control valve” on its SkyActiv-G 2.5L / 2.0L NA until 2018 MY when they introduced the cylinder deactivation to the 2.5L NA. The 2.5T based on the 2.5L NA was introduced in 2016 MY for CX-9 which keeps using traditional mechanical thermostat without the “update”.
Yes, there’re many fixes aren’t a true fix from the root, but only cover up the symptoms. The fallen rocket arm problem on CD equipped 2.5L NA where Mazda came up a fix on PCM software to re-adjust and lower the oil pressure on switchable hydraulic lift adjusters that IMO only masked the true problem but sacrificed the longevity of the components.
But honestly this isn’t just the problem on Mazda, but on many car manufactures and many industries.
⋯ I am beginning to believe the root cause is the current generation has not suffered the hardships of their predecessors. Much like the 2nd generation of WWII Americans that led us into the late 70's early 80's when the quality of American goods tanked. We becamae complacent and lazy. Japan was ready.
You may just hit the nail on the head on this, unfortunately.
It’s very likely to be China IMO. All iPhones are made in China with excellent quality until last year but who wants an iPhone which is made in India?
I stand corrected ;) I thought when I was researching this, the issue surfaced on other models earlier but I may be mistaken as that was a while back.
I will comment that their warranty extension ONLY covers the valve replacement not other issues that may result because of it.
I had forgotten about their clutch issue they refused to take ownership for. It was a Mazda 6 with about 28K. The discs would start coming apart causing a pulsing or purring like a kitten as my wife described it. I should have taken note of their not accepting responsibility as it was a very common problem. A sign of things to come :(
A very sad example IMO for what once was a great manufacturer. They have lost sight of what it took for them to get there.
If only I could buy that 83-85 626. Comfortable, excellent mileage, adequate power, easy to maintain etc.
