How did you notice the leak? My coolant level is getting lower over time but I don’t spot obvious leak yet.It's a 2019, with just over 62k miles, a large percentage of which is on the freeway. It just started leaking coolant with the last tank of gas.
It started as a slow leak, but it isn't slow anymore (we're not driving it, but I started it up recently just to move it and lost about a quart of coolant in a few minutes of idling).How did you notice the leak? My coolant level is getting lower over time but I don’t spot obvious leak yet.
Thanks for the info. I also drive a lot on highway. Recently the coolant level seems to drop faster. Now I just hope i found the issue within warranty. Mazda shouldn’t refuse to cover it just because you didn’t go to the dealer for oil change, especially if yours just passed warranty. You may want to call them again and try a different agent and mention that TSB if not done yet. This is their design issue and has nothing to do with oil changes.It started as a slow leak, but it isn't slow anymore (we're not driving it, but I started it up recently just to move it and lost about a quart of coolant in a few minutes of idling).
My theory is that because of the plastic shield under the engine, the leaks land on the shield and blow off while driving, and unless you sit in one place for an extended period idling, there won't be enough on the tray to leak to the ground until the problem gets bad (there are lateral stiffening ridges on the tray that allow it to hold several ounces of liquid, but bouncing down the road and wind will remove it while driving).
Initially, we were seeing small puddles on the ground under the car. We wouldn't have noticed it if the undertray/splash shield were still in place under the engine. But the dealer had removed it looking for a clacking noise, and then never put it back on. (And I didn't notice that the shield was gone for several months, by which time the dealer denied that it was their doing. They also cracked the plastic cowl piece, likely from closing the hood with something on the cowl. Those two things were why I stopped going to the dealer for service, and not going to the dealer for service (for the past year) is one of the reasons that Mazda gave for not covering the repair costs).
How can you tell this issue is only on Signature and Reserve only? please help i am looking to buy one in canadaCX-9 2.5T Engine Coolant Leaking TSB
Moderator edit: This is a copy of a post originally made in another thread. This thread was created for easier reference. Mazda recently put out this TSB for coolant leak because of cracks in the cylinder head. As reported by many here it seems to affect the 2.5T 2016-2020 CX-9 as well as...mazdas247.com
Applicable to 2019-2020 Mazda CX-5 GT Reserve and Signature trims (refer to VIN range).
Because this coolant leak problem caused by the cracked cylinder head is happening on the 2.5T which is only available on CX-5 Signature and GT Reserve. Mazda did modified the cylinder head and exhaust gasket to prevent the head cracking since 2021 CX-5 with the 2.5T.How can you tell this issue is only on Signature and Reserve only? please help i am looking to buy one in canada
Oh I didnt realize you were talking about CX-5s. I was referring to CX-9s. I think all the trims have the tubo on CX-9s. Also reading the TSB it says "US spec" does this include Canada as well? Appreciate your helpBecause this coolant leak problem caused by the cracked cylinder head is happening on the 2.5T which is only available on CX-5 Signature and GT Reserve. Mazda did modified the cylinder head and exhaust gasket to prevent the head cracking since 2021 CX-5 with the 2.5T.
Unfortunately there’s oil consumption problem from exhaust valve stem seals from the 2.5T on 2021 CX-5 with the 2.5T.
This thread is under CX-5 category and CX-5 does have 2 different engines. Unfortunately both suffered cracked cylinder head problem with different symptons.Oh I didnt realize you were talking about CX-5s. I was referring to CX-9s. I think all the trims have the tubo on CX-9s. Also reading the TSB it says "US spec" does this include Canada as well? Appreciate your help
Prefix was updated to match the current gen year range and can only be done across the board...Thread title updated (prefix removed).Why does the title say 2017-2025 when the issue is up to 2020 2.5T models?
Plaintiff Matt Cauller’s class action lawsuit claims Mazda failed to disclose that its SKYACTIV-G 2.5T engines equipped in certain of its model year 2018-2021 Mazda6, 2021-2024 Mazda3 and CX-30, 2016-2023 CX-9, 2019-2024 CX-5, and 2022-2024 CX-50 vehicles were defective.Seeing there’s a lawsuit against Mazda for this issue and the affected cx5 is listed from 2019 to 2024 (so all cx5 with 2.5t):
So seems the change Mazda did doesn’t really fix the issue…
I think there should be a disclaimer at this time since it's unconfirmed and not official
