For those that have issues with rear brake dust, AC, and rattling from rear.
Go this link
http://www.finishlineperformance.com/mazda3/bulletins_index.html
They have a Serice and Parts Recall Bulletins. You can download the pdf file that suits your problem. Then make sure your car is within the vin number recall or problem issue. I hope this helps for some people.
Here is the list.
2004 MAZDA3 Crash Zone Sensor Recall
Engine Vibration / No. 3 Engine Mount Rubber Broken - Issued 07/13/05
One-Touch Power Window Stops Halfway
Brake Squeak / Grind Noise From Rear Brakes
Mazda3 i Trim Level (4-Door) Accessory Fog Light
Front Brake Squeak When Cold
Front Door Rattle
Front Crankshaft Bolt Service Warning
Drive Belt Tensioner Pulley Breakage / Charging Warning Light On / Overheating
Brake Rotor Grooved
Trunk Lid Difficult To Open
Engine Hard To Start
Driver Door Lock Inoperative / Room Light Stays On
Information Display Shows Bars
AC Poor Performance
Tire Pressure Monitoring System Warning Lamp Illuminated & Warning Buzzer
- Service Tip
Power Window Inoperative
Fuel Delivery Module Installation
O2 Sensor DTC Error, P2195/P2196
Loose Door Trim Screw Cap
Front Wipers Do Not Wipe Well
Abnormal Whine Noise From Steering System
Room Fuse Removal / Installation Caution
Stains on Paint
Squeak Noise From Rear Brakes
Splashing Sound From Inside Dash During Cold Start
Scraping Noise Over Bumps From Right Rear Wheel
Seat Belt Minder Deactivation
MIL ILLUMINATION WITH DTC P0128
Water Droplets / Moisture Inside Front & Rear Lights
License Plate Frame Installation
