SO I had said I was gonna wait till next weekend.. But I couldn't wait. I spent 30 hours over the weekend working on this thing. I am spoiled and got to used the climate controlled shop at work.. I accomplished a lot.
Rolling in
Radiator coming out.
Not too shabby color considering what it came out of
Tiny crack.. it doesn't not wrap around to the back (I checked) I will MIG weld this maybe next weekend
Considered doing it, but realized I might not have time
Exhaust leak much? lol
Cool trick. Routing the vacuum line for the boost gauge. Started with some wire and a tire plug tool
I've heard people struggle with this. Its 26mm. Being a shop that primarily works on trucks, I didn't have any issue finding a wrench for this
BAM! That looks so good...
Still leaking oil a little. It looks like its coming from those.. Its easy enough to fix.. just didn't have time for it
So I guess this is "not bad"? You tell me
Same pic, but with flash
Was gonna cut there... but decided to drill out those two spot welds instead
LOL everything is COVERED in PB blaster
Found out that one of the turbo mounting brackets is broken. I still haven't fixed this. I think I will try welding it first.. then I will fabricate a new one if that doesn't work. Looks easy enough to make
Pulled the whole turbo assembly, from the cat to the manifold. Cleaned and inspected. WAY less oil in there. I didn't see any on the turbine.. But I suppose at 120,000 rpm, you wouldn't.
The exhaust leak was significant (the wetness is mostly from all the PB blaster)
Those valves are more light grey in person. Although that was surprising to see them not black.. being as rich as we run.. But I was flashed in 2006, if I am not mistaken. You can also see the broken bolt I have been talking about for 2 months now. its been broken for a WHILE.. same color as the metal around it
It looks like a new DP is in the future. This just looks terrible to me. (maybe its not?)
I successfully extracted all bolts. One the one in the top location for cylinder two had enough meat on it to use vice grips The bottom, cylinder 1 bolt was about 2 mm below the surface of the head. I actually slept in the garage in my car (its 20 minutes from home). I had a dream about how to extract it.. I used a center punch and a 5/32 drill bit. (smallest I had) I center punched the middle, 12oclock, and 6o'clock... drilled each about 2 mm deep, then gently coerced the bit across the space between... connecting the holes. Then I used a flathead and it came right out. SWEET!
This tool works pretty good, but I had to make the hole bigger to accommodate the 45ish degrees I ran the pipe threw there (due to not enough 90* couplers)
I did the 180* pipe for the hotside, snaked under the frame, keeping my windshield wiper fluid container. i had to use like 6" of extension and an extra coupler to get it where I wanted.
Also, I was nearly screwed. I didn't have enough clamps, or couplers, or pipes for that matter. I went to Autozone and spent $77.00 on Spector parts to make it happen. Of all the stuff I bought, I used 2 clamps off the filter. didn't think I had enough pipe to run the good filter I had bought (2.5"). Turned out it would have been way harder to go 2.25" to 2.5", then 2.5" to 3.0" (the spector stuff).. and still fit the blue, 3" pod filter. What a waste of money.. but I was in a pinch. (leaving this car in the shop was NOT an option - I would have gotten my ass chewed out for anything other than weekend use of the shop)
The scene
So here is where I stopped
Yes, the bumper has been hacked up.. There was no way around it. I may not have wanted to do it, but I didn't have a choice. I will do some measuring and fine tune type work on it soon. Its gonna be chopped up though... (shrug) At the end of the day, the tab on the passenger side, that holds on by the headlight was broken, and upon further inspection there is actually a crack in the bumper and I am pretty sure it was repaired when dude drove the car off the road years ago. I am probably gonna look for an after market bumper, thats meant for a front mount.. Like the B2 maybe
Last one for now.. Under the hood (Yes my air inlet temp sensor is painters taped to the pod filter. It works. I know its INCREDIBLY ghetto... but keep in mind I did all this in 30 hours.. and I took a lot of breaks.. and I work really slow. lol
