TPMS warning light won't go off
I had my winter tires installed and now my TPMS light is on. I was told to reset but I don't have a TPMS reset button. I drive a 2015 Mazda 5 van.
Any suggestions?
Clayton
You guys got TPMS?
:p
Canadian Mazda5 edition is probably one of the last cars here that came without the system.... and honestly think I like it better not dealing with this twice a year.
Upvote 0
Ignore it? I've put a piece of tape over mine and just carry a $1 gauge to check air pressure like we always did.
If you truly want to fix it, you have to make sure each wheel has its TPMS sensor in it with a good battery. Then you need to fork over $100 to a shop to reprogram it. If you don't have the sensors, you need them to pull the tires off the wheel, add the $50 sensor to each wheel, re-mount the tires,re-balance everything and reprogram. Probably $500 total?
Piece 'o tape and a Wally World air gauge is sounding mighty nice.
Upvote 0
I don't know about the Mazda 5, but for other Mazdas, programming isn't needed if you buy the right sensors. They just sync up automatically. But yeah, you needed to get them put in when the tires were mounted.
Upvote 0
You do not need to program TPMS on Mazda5
Upvote 0
Any suggestions?
Clayton
Normal physics, cold air, winter thing. You need to add some psi to your tires.
Upvote 0
