Mazda OEM PE5R-18-110A spark plug is the most expensive one available.  Many have chosen NGK OEM equivalent ILKAR7L11 / 94124 iridium spark plug for a half of the price.   See
@txt990’s post in post #12 above.
Nobody believes there’s the life-time fluid exists.  Since there’s no said maintenance schedule for ATF and gear oil changes, we can only use most opinions from DIYers experience.  Many believe the ATF should be changed at 50K ~ 75K miles.  You can only do the drain-and-fill for Mazda’s SkyActiv-Drive automatic transmission, and you can only drain a half of the ATF out hence you shoul do it 3 times with some interval in between.   Whether you should drop the pan for filter cartridge change inside, or when do you want to do that in 3 drain-and-fills, is a personal preference.
2016.5 CX-5 Transmission fluid change questions
2014 CX5 Tune-Up items to replace?
Guide ATF Drain/Fill
The same no life-time fluid theory applies on how often you should change the gear oil on front TC and rear differential.   50K ~ 75K miles would be the change interval most people use.
