You haven't said anything i disagree with, however I don't race anywhere. I pootle around the single lane roads within/at the speed limit and cruise at 70 on the motorways. I'm in a cheap car with a small engine and when I want to overtake, the torque is helpful. even at 70, if i want to accelerate to 90, i don't have to downshift from 6th, it just goes and doesn't need an appointment.
unfortunately our country has tied CO2 emissions to road tax and this was put in place to incentivise diesel uptake, ultimately, to pacify the European court's need for CO2 reduction. I'm a lot disappointed with them ignoring the other emissions too. I will probably look to petrol or petrol/electric hybrid next to do my part for the atmosphere.
I have to note, personally, diesel has not cost me more than petrol in vehicle maintenance, so my next move to a petrol plant won't be based on higher costs or lower reliability.
True. Mazda needs to get in an agreement with Tesla just like rav4 and Mercedes b class did. Added hp and torque would be good. Got my oil change done and this was my first. Think i will be getting 30+ mpg on my mixed commute. 45mph/30+ mpg ftw.Unless they buy the hybrid technology in, they have such a long way to go. Toyota have probably spent more developing that technology than Mazda have on the entire range.
Changes indeed were made to SkyActiv-D 2.2L diesel by Mazda for NA market. But it only added urea injection to meet US emission standard. Urea injection system has been used on diesels for many years even in the US. I wouldn't worry the technology itself. But I believe with added expense of periodical urea refills, and the problem of completing the full DPF regeneration cycle, the MPG saving on diesel simply becomes worthless. That's why even VW is giving up on its TDI and thinking the diesel market is dying! I'm really questioning the wisdom of Mazda trying to come out its diesel at this time to a very limited US diesel market!I'm not averse to the transmission shifting gears. Torque is nice though, and all things equal, I'd rather have the performance of the diesel over the gas burner, but not at the cost of an unproven design. I don't know what changes were made, but changes WERE made to the NA vehicles, I betcha, and I am not going to be a guinea pig.
True. But rotary engines first need to overcome the emission issue which is hard to do like 2-stoke engines. The oil consumption、fuel economy、and reliability are also the hurdles need to be overcome!Mazda makes the current Toyota Yaris's at its Mexico plant, complete with skyactiv engine. I would think they would partner with them for hybrid drivetrain. I wouldn't count this out- a few years ago they had a prototype hybrid with a rotary based range extender. Rotaries are great for this application because it runs at a constant speed and its more compact than other engine types.
Mazda's low-compression SA-D diesels do have their uniqueness. But only very limited diesel fan in US would be interested to get one. The timing is totally off. Mazda should simply add the urea injection and sell the diesels in the US few years ago. Now they're giving up their belief of not using the urea, but it's years too late!
My advise is don't rush out to buy one, let someone else test the waters.
Lots of engine problems throughout the world with the diesel engine. Worn cams, vacuum pump failures, both leading to further problems such as turbo failures, and total engine failure.
I have the 2.2l diesel with 175hp optimized to 210hp drive most short distance in the city but did not want to miss the fun of the Diesel engine!
For the diesel/DPF reg discussion, if the oil liquidity is to high and you get the warning from the computer before the regular service it is up to Mazda and you should/will get the oil change for free.
I know guys they have not payed for the first three years due to this normal/issue at Diesel engines. Just a month or two before the regular service. Don't panic for the warning of the board computer wich is a bit harsh and threatening. You can still drive short distances for weeks or even drive back smooth from a holiday trip home to your mazda dealer. Just check the oil level and give them a call to confirm the situation. I had this like all diesel driver I know.
All big car comp have this issue if you read their forums.
I always bring the Mazda original oil which I ordered online to save on it more then the half compared to the Mazda dealer at regular annual service period.
This is now in fact Mazda's problem not your, just extend the warranty all the time that they will cover any damage of the engine.
You can be concerned about the reg and always drive it till the end or see it like me after a while and just interrupt it if the journey is over. The modern engine with the computer can deal with it. I use a modul wich show when the reg is active also with a LED that you can see if the reg is active + you can also feel the reg while driving. The reg is always around 200-220km least for around 20km. If you interrupt it it will start again when the engine got the right temperature. Sometimes it already starts with around 65'c.
More concerning for me is the weak crankshaft which afterwords lead to a defect of the turbo.
Cheers 101
According to one video i saw of the cx-5 the chap looking at the transmission consider it only ok for the standard output power, so i would suggest its unwise to increase power with out first reseaching the limits.
The chap from Germany more or less confirmed! I also thought the wear problem was the camshaft not the crankshaft, although i also read the crank was lightweight to save weight, the reduction enabled by the lower comppresion ratio. Another reason not to increase power, maybe.
OK, y’all are making me nervous, LOL. Reading this thread and other comments, it sounds like diesels are more complicated. Can you not just put in diesel fuel and drive, like a gas engine? I was excited at the prospect of a diesel because of possibly better mileage, but now I’m not so sure. Never driven a diesel, and my current ride is a hybrid. I’m a commuter driver who takes occasional road trips in excess of 100 miles (mostly just family trips out of state about 500 miles one way, for Christmas). Urban environment, surface streets – so about 80% of my driving is stop and go (which is why I got the hybrid, 10 years ago). Is a diesel an appropriate engine for me?
The VW engine is quite good but so is the current Mazda. Look, for most people the diesel will be fine but there are things that will make it trouble free and as long as this urea injection doesn't effect fuel consumption, it will give good economy and tremendous fun.
