- 2014.5 CX-5 GS FWD 2.5L
Used up my 2 freebie changes, so going to do the next one myself.
Can someone confirm what size of allen wrench/socket I need for the plug.........8mm or 10mm ???
Also there was some talk on the drain plug leaking because of the washer. ( I have not had that problem). So the filter came with 2 washers. One is a solid metal, and the other is metal with a built in rubber washer portion.
Can I use either one.??? Or should I replace with whatever is on the engine right now?
2014 2.5L
2014 2.5L
