Right, hopefully I can be of use.
I have CX5 in the UK and was one of the first cars to exhibit the oil dilution. I was at the point of rejecting the vehicle but am now comfortable it is being addressed. With these issues I have had a number of conversations with a very senior tech at head office and hopefully the info I have will help people.
Firstly coming from VAG group cars the issue did really concern me, however after some discussions and further research it would appear that the following points are correct:
Mazda diesel IS supposed to dilute the oil to a certain extent
The engine is designed to cope with a level of dilution and hence less effective oil, ie upgrade shells etc
The oil Mazda specify in the UK(at least) has been specified to accept dilution.
There are 2 issues as to why they sump is filling up too fast, bear in mind I had mine changed after 4000 miles!
1. The ECU is over injecting fuel during some of it's pre ignition phase during certain load scenarios. Ie too much fuel is being constantly injected and finding it's way into the sump. Also the regen fuel inject in some circumstances is too high.
2. The dipstick X should be at 24mm above max not 13mm as manufactured. I WAS SKEPTICAL ABOUT THIS! However I was honestly told and I have no reason to disbelieve them that it was a calculation error. The same engine using the same method of DPF regen is in the Mazda 6 just without skyactive elements and the X is apparently at 24mm on this model.
Fix in the UK will be as follows:
New dipstick at 24mm
New ECU flash Jan - Mar for the pre ignition fueling
Further ECU flash later in year for reduced regen fueling following final testing.
I also understand the oil dilution is significantly faster as the engine beds in which marries with my experiences, hence Mazda ship the car without full oil. My dilution rates have now dropped off dramatically.
Overall I think they will fix the issue and I'm now happy with the vehicle. Generally I'm pleased with the car, as regards the engineering sense to allow the oil to dilute, all I can say is there are a number of manufacturers all with the same issue. Maybe Mazda are there own worst enemy in that they build a very tight engine which doesn't burn ANY oil hence dilution pushes it up. Other manufacturers may burn oil so the level drops as people would expect even though it is becoming diluted. If this is the case then the Mazda method is actually better as dilution levels would be lower!
Hope that have been useful to everyone.
