Gb: Awr deep sump oil pan
Status
Not open for further replies.
HKPRO5
Supercharged Protege5
GROUP BUY CLOSED
Hey everyone,
We are looking to do a group buy for the AWR Deep Sump Oil Pan. We will need at least 5 to complete the group buy. So far the pricing is going to be set at $315 shipped. (Continental US only- all others PM for Shipping quote)
GB List
1.) Funkalicious21 OUT
2.)repthemazdas Payment Sent
3.) Perro del Sol Payment Sent
4.)Mazdaspeedp Payment Sent
5.) HKPRO5 Payment Sent
6.)Bikingpro5 OUT
7.)BRIAN MP5T Payment Sent
Payments can be sent after the October 17th (please don't send them before)
Paypal SpeedCircuit@gmail.com
ALL PAYMENTS DUE ON OCTOBER 21st
There can be more than 5, just add yourself to the list. But a minimum of 5 is needed to get the GB going.
Thanks
Cres
Whats the ETA of the pan? I need to take mine off cause it has a leak and If this will be around Christmas Ill get my self a Christmas present.
Adds 1.5 quart extra capacity to your Protege and Defend against spun bearings and eliminate the risk of oil starvation witch is comon for our engines :(
whats the benefit of using one of these pans , and will it work with the 1.6L
Our cars have an issue with oil starvation, especially on road courses, the pan does hold an additional 1.5 quarts that was alluded to in th previous post, but it helps to eliminate oil going completely to one side of the pan, unlike the OEM pan.
it adds the extra oil but how does the car recirculate it, looking at it, most of the excess oil is down that hole there...please elaborate, i'm interested...
There is a oil pick-up that goes into the bottom of the pan from the block. This pan doesn't appear to be much if any deeper, just out more on the bottom. With this engine, if you are low on oil and make a hard sustained turn you will likely spin a rod bearing. The oil sloshes to one side of the pan leaving the pick-up open and sucking air, if your engine is at a higher rpm you've had it. If its at a low rpm you may see the oil light come on and have enough time to do something about it. I would be interested in one of these, but not right now.
ill take one of these forsure i need it for my motor build.
1.) Funkalicious21
2.)repthemazdas
3.) Perro del Sol
4.)Mazdaspeedp
5.)
Status
