Mazda3000GT
- Mitsubishi, 3000GT, VR4
It is a complete CHRA replacement. The housings are machined out to fit the CHRA. 100% bolt up no fabrication required...
How about the stage two, what exactly needs to be done to get it on?
Thanks it wasn't clear to me before.
So the Stage 2 is just about equivalent to a GT28 disco potato turbo? That's a nice turbo...
Then what is stage 1 equiv to? A gt25?
I'd be interested in the stage 2 but I don't currently have a shop that could custom make the inlet pipe and fmic pipe. I'd have to change the downpipe as well? Seems like a lot of extra expense at the end of the day.
How much better is the stage 2 vs the stage 1?
Sorry to badger you. I'm very interested.
The stage 2 is the same CHRA as the stage 1 (both are GT28 Disco Potatoe). I was going to use my custom GT28X compressor for the stage 2 but availability of the wheel was going to be hard to maintain. So I am staying with the Disco for both turbos. The gain from 1-2 is in the compressor housing volute. Thats the passage inside the comrpessor housing. When you make that larger, there is more area for more volume to compress. It helps spool and gains power at the same time.
It is confirmed that a 2 year warranty is optional! (attn)
where are you located at bryan@bnr ???
Thanks Bryan. That makes it clear the stage 1 will have a nice chra that is bottlenecked by the housing. Will that lead to reliability issues or heat build up? Will spool be "bad" in that configuration or still reasonable?
I'm very interested to see how that works out. In the smaller housing I'm concerned that the stage 1 will favor early onset of torque, which is already a problem with this engine. Too much torque too soon.
Do you need a guniea pig?![]()
Well there are a few people running around now with their turbos. Updates, install pictures and information are on the other ms clubs.
i would like to see that information posted over here bryan, could u copy and paste it, if not send me the link of where this information is located.
i love how they dont even let you link to other sites, what a damn joke. mods need to stop being so up tight around here. /rant back to topic
