blackwidow
- mazdaspeed 6
I will be on the dyno with the BNR stage 2 turbo next monday , for now the turbo pull very hard at only 15 psi .
292 AWHP and 311 AW torque at only 18 psi . I want to keep the boost at this level because i don't want to be in the BOOM club !
I think the biggest problem with trying to force a smoking turbo fix from Mazda is most of the vehicles smoking are not stock. You would be hard pressed to find a large enough sample of stock, smoking vehicles to consider a macro recall of turbos from gen 1 MS3's.
Wht about all the cx-7's ? not a big mod happy crew there
We have set my boost by rpms but did not get much driving done this fall. The clutch was feeling the strain of more boost and was actually slower in the quarter mile ( stock turbo, CPE managed) I look forward to playing and learning some more with it this spring before i go with a little bigger/better BB turbo too. My tuner son was bringing in the boost gradually till he asked for 21lbs at 5250 till 6200. I think that is just hot air at that point so we have much to do yet. Also i do not have the program loaded on my home computer so can not send any data maps out yet. Everything is on one of his laptops. But these dyno pull numbers are pretty big i think and something for us to shoot for. well done, but you know you gotta back it up mister! Keep us updated, please and enjoy the Mazda Speedemon, Black widow.From what I`ve learned so far, you can set the ECU to demand full power only at rpm ranges you select. If you ask for it only in the highest rpm range, you can set a higher boost level and save the engine from a beating at low rpm loads.
merry chrismax to everyone. One question: what meens ''not enough backpressure to equilize crank case pressure''? I want to understant
