Yep, wind her up on a LONG flat downhill cause it will take a while. It is set for 154.5 but you can get past it using the method I mentioned But you sure as hell better have the experience, because things happen very fast and a mistake, even driving in a straight line on a smooth road is terminal.I know the speed3 has a speed limiter set for 155... is there a way to remove that? I think a new ecu would solve that, but is there a way to do it without buying a new computer??
Man, you got that right! All it would take would be a critter or a rough spot in the road.Yep, wind her up on a LONG flat downhill cause it will take a while. It is set for 154.5 but you can get past it using the method I mentioned But you sure as hell better have the experience, because things happen very fast and a mistake, even driving in a straight line on a smooth road is terminal.
ive only done 135 to date on i90...which was a dumb idea considering the number of cops that chill there... but yea id still like the ability to go over 155 whenever possible ;-)
