i should not be experiencing fuel cut. In the boost settings, under advance boost your boost clip is set to 13 psi. Meaning your map only sees 13psi.
Do you have a aftermarket bpv? CAuse mine did this before and after the standback. I put the stock valve back on and all my problems went away. Theres dones of poeple complaining about the stutter/backfire issues at high rpms in the cold weather.
