Started a seperate thread to post the progress of this project.
Finally..they are in. So far they look like a good match. The Fuel Rail connection is identical and the wire harness connection is the same. The WRX injectors are about 2.5mm taller...nothing that some spacers wont fix.
My only concern at this point is that the "spray" end has a 1mm smaller diameter than the Mazda ones. I will need to see how they sit in the intake manifold...maybe I will need some spacers.
The spray pattern will also be different...as the WRX has 12 "holes" versus the mazda's 4. The 12 "holes" are noticably smaller than the mazda injectors.
The Stock Mazda Injectors are measuring about 15.6 ohms resistance. The WRX are measuring about 13.2 ohms. They are both High impedance [12 - 16 ohms] ....which isn't a concern since most aftermarket ECUs can adjust for low or high.
I am not yet ready to throw them in....but I will try to mount them on my "old engine" for fitment....I will probably do this on the weekend.
I got them for next to nothing from a friend that just upgraded his Turbo and went with STI injectors.
And for the new people to this thread....YOU WILL NEED SOMETHING OTHER THAN YOUR STOCK ECU TO CONTROL larger injectors.
oh...and special "Thank you" to Turboge on his input on this particular injector project....
I will be eventually utilizing the 440cc map from Haltch as a base for tuning...
Here are some pics:
Here are some pics:
