Guys (or guy) do you have any comprehension of how Forced Induction works? Turbo or Super, the point of it is to blow more air into the engine. PSI has nothing to do with the amount of air that is flowing. Think of it this way. If you have a million gallon water tank (think Shamu) and you have two openings in the bottom of the tank, one is 1" and one is 100", a lot more water is gonna flow out of the 100" one, but it will only go a couple feet from the opening. But the 1" opening will flow a MUCH smaller amount of water, but it will squirt out a lot longer and do it at much higher pressure.
It's the same concept with FI. More air gives you more power. If there's only 100 cubic feet of air going into an engine every minute, even if it's in a teeny tiny pipe that compresses the air to the point where it's at 30 PSI, its not gonna produce anywhere NEAR the amount of power that 1,000 cubic feet of air per minute will produce. More air=more fuel=more power. Even if the device pushing 1000 cfm only blows at 10 psi, that means that at 30 psi it will blow 3,000 cfm.
Are you following me here? I'm not trying to be a dick, even though you're insulting my friend, I'm trying to not be an asshole, just to educate you. Let me know if I am, but I swear I'm really not trying to. And if you dont know, just tell me and I'll explain it to you. Everybody has to learn, and you probably know more about nitrous induction than I do, so just tell the truth.
