- 2015 BMW 335i Sedan / 2015 Nissan Pathfinder Platinum 4WD
Maybe he just didnt know when to shift...like I said its hard to say, but I dont think its impossible...
MSP Pro said:RX-8 Automatic: Torque 164 Curb Wt: 3053
Mazdaspeed stock: Torque 160 Curb Wt: 2810
Mazdaspeed @ 12psi: Torque ??? Curb Wt: 2750 with a quarter tank of gas
So, why don't you think our Mazdaspeed Proteges can't out drag an RX-8 automatic?
Pkay said:RX8
Sports package (6speed): with your mods you'd have only beat it if it was a bad driver
The 5speed automatic- well, our car with your mods without the ECU flash could have taken an automatic rx8....... it doesn't have a turbo.... it has no jump.... at the low end you woulda roasted him but he woulda caught up later.
Anywho, like someone said the RX8 was never designed to and will never replace the RX7. The RX8 was meant to be a 4 seater sports car. It's a car the emphasizes design and quality and in all honesty they accomplished that. It's got quite a few unique interior and exterior design aspects and mechanicly it will be the first reliable rotary engine.
Ah HAH! I knew I was being conservative!servoeyes said:12psi=5 more than stock. At stock, we can pull 160 whp w/ the new flash. Every pound you add can add from anywhere between 7-10 whp (this is a common rule of thumb) so... 7*5=35whp+160whp=185whp min. Maybe he's more efficient so we'll say 50 more whp...now we're at 210whp. Doesn't seem like much....but take into account that the torque will be at 185-190 ft/lbs min.(from empirical data and inference) then it seems quite a bit closer. Note also, that the RX-8s have not dyno'd very well at all.
Don't get me wrong...I love that Mazda brought back a rotary; I'm an engineer...we love this crap! I just think that it's not quite the "sports" car it is portrayed as. Or rather, it's not quite the sports car that some people thought is was replacing. (evil)
brennan said:at 12 psi he has around 185-195whp so why is it so hard to believe?
Pkay said:Actually you can probably pull 155 at best with simple stock and flash. The ECU doesnt add but maybe 4 or 5 HP... it just optimizes it in the right areas
You also gotta take into account that you don't get the same amount of gain for each and every PSI you add.... it actually lessens for each PSI you add. So while you get 10hp extra at 9psi you might only gain 6hp going from 10 to 11psi.
Here are the ONLY 2 dynos known to have been done with the new flash. Like I said.... an RX8 automatic.... any decently mod'd MSP could probably take. The 6speed..... well ..... that's not gonna happen with said mods unless the driver is s***
