Like I said dude.... check the dyno charts above. You can see where we get the jump.
So going by everyones implications since I'm running roughly 160hp right now..... and had i had a fan and another run or so I'd have pulled 165hp.... and I'm runin the usual 6.5psi stock boost
So if I add an mbc to my current setup..... crank it up 5.5psi higher.... then my car is going to be pushing a steady 220hp?
Joe P might be able to pull that off.... but Joe P knows how to tune a car beyond 99.99% of the people on this board know how to.
Even with the flash if I bumped an MBC up to 12psi I'd be surprised if I passed 190hp
About the RX8: you've also gotta realise the people driving the rx8's arent the same as the rx7 drivers. RX8 drivers aren't the power hungry aggressive, piston eaters that us rx7 owners are
