So much misinformation around here (bang)
91 octane will make you go faster because your wallet would be lighter. Power/weight ratio. Helloooo!!!
Technically yes, but it will not be noticeable at all and it is not worth the extra cost.
Higher octane fuel is more difficult to combust. When it does combust, it creates a slightly more powerful explosion in the cylinders than lower octane fuel. More powerful combustion means more hp.
However high octane fuel exists for higher power or forced induction (turbo/supercharged) engines because they are more likely to pre-ignite (A.K.A. Engine knocking). That is when the combustion in the chamber starts before the cylinder fully compressed. This damages the engine and causes a loss of power. That is why most turbocharged cars, supercharged cars, high revving cars, and high hp/liter engines require premium fuel.
In a car tuned for 87 octane, using higher octane fuel will not make your car healthier or last longer. It won’t give you a noticeable increase in power. The power increase is so minimal that the 0-60mph time would likely be the same down to 3 decimal points. Some cars cannot even use higher octane fuels because their ECU’s are not programmed to adjust to varying octane fuels. Also, with a higher octane fuel, you need more air and more spark to ignite the fuel more efficiently. In some cars, that might mean that you will need more powerful spark plugs or a better air filter to combust higher octane fuel efficiently.
Solution: ecu tune and high flow panel intake or cai/sri.
Chris did you see Corksport's new cold airbox yet?
Your first paragraph is not accurate. Higher octane fuel has no more or less energy than low octane. Higher octane fuel simply better resists premature detonation which can damage an engine. This misinformation is everywhere.
http://www.nicoclub.com/archives/gasoline-octane-myths.html
+1.Your first paragraph is not accurate. Higher octane fuel has no more or less energy than low octane. Higher octane fuel simply better resists premature detonation which can damage an engine. This misinformation is everywhere.
"Once there's no need for a high peak horsepower, there's no need for a huge turbocharger-and that means much less lag. Indeed, peak boost happens early, resulting in a healthy 310 lb-ft of torque at 2,000 rpm, which then fades from there."So much misinformation around here (bang)
"If there's a drawback, it's that the CX-9's torquey engine promises more muscle than it's able to deliver when all-out passing power is needed. At very high engine speeds, boost (and output) begins to drop off. And the 2.5-liter gets a bit raucous."
- Motor Trend March 2016 issue.
If SA-G 2.5L turbo can gain 23 hp, 10% more horsepower by using 93-octane gas (and premium in our area is 93 instead of 91), I would use premium gas on new 2016 CX-9 without hesitation.
Of course the big EGR cooler we saw in the video is very interesting and unique. Hope this aggressive EGR system from Mazda can really improve the real-world fuel economy as advertised.
Although I've always been against turbo engines due to the concern of their longevity, this particular SA-G 2.5L turbo could make me to think twice and even change my mind.![]()
I have been running premium in my 2011 328 for 5 years and can careless about the added cost. My motto is, if I can't afford the gas, than I shouldn't spend 40+ grand on any car!
The CX-9 doesn't require premium, it's optional. And I think you mean you "couldn't care less" about the added cost.
"Could care less" means you care more than the minimum amount. Couldn't care less means your level of care is already at the minimum and can't go any lower.
Just saying.
