I got so tired of seeing this question appear and reappear here that last week I ran the tank down to fumes and filled it with premium. Ran it for a week and noticed absolutely no difference under any driving conditions. Back to regular!
New CX-7???Thanks for the reply, I just read a article about new cx7, it says if you use 91 octane gas it will have ten more horse power then 87. I am just not sure will cx-5 do the something.
I usually put 87 octane gas in my car but since the gas is very cheap now, what if I add 91 octane gas, will engine run better?
The new CX9 has different HP ratings depending upon octane. There is no reason to waste your money on premium for the CX5. (Unless you've got an aftermarket performance ECU tune).
????????????????????????The new CX-9 has a turbo, so you would want to use 91 octane at all times.
The only way you would benefit from 91 octane is if you got your car retuned for 91 octane.
Mazda is not trying to jack up power number with a turbo but emphasizing the low-end torque as most large CUV drivers rarely exceed 3,000 rpm.
Yes, it'll make more torque with premium too. But Mazda has admitted most drivers will normally run 87 octane because it's cheaper and more power isn't actually needed or noticed in regular, everyday driving.
According to Mazda the torque is unchanged with the octane rating.
https://m.youtube.com/watch?v=WrY4g9EAveg
