I'll guess a high 13. I need to go to some meets, unless he's sandbagging runs it will only take a few races to figure it out.(smoke)Gen1GT said:I still don't know what times you run.....
3 months ago i did 14.4 at 105mphGen1GT said:I still don't know what times you run.....
Are you using the stock AFM for that? I'm running one in my car, and I wondered about the upper limits of airflow it was capable of...FC3s Boy said:my n/a FC rx7 runs a 14.8 with my old set up 15-160rwhp ( on a bone stock motor) with my new high comp. ported motor i should be 215-225rwhp . It should be in the 13's easy ( I have nitto 555r's) all of this is out of a 1.3l motor.
yea i am using the n/a AFM , which is good to the 200whp range on a 7, I also have a turbo II AFM that is going in with the turboII injectors which is enough fuel for 300hp easy. The turbo II afm and n/a afm are interchangable with each other, so if you need a little more fuel for the 1st gen you can always use the turboII afm.Gen1GT said:Are you using the stock AFM for that? I'm running one in my car, and I wondered about the upper limits of airflow it was capable of...
Install, I have a G35 in my car, and I run it to 7400 all the time and haven't had any problems. Don't know if that info helps any, since honestly, I really don't know much about the differences in the Mazda trannies other than gear ratios. I know the G is a lot stronger than the F though.
