CheeseHelmet
Did a little inspection under the car and found a 4cm by 4cm hole in the floor in the back on the passenger side. Grrrrrrrrrr.
Are you going to be boosted? Or did you mean MP3 ECU? MSP ECU on an NA P5 should lose power and run crazy pig rich
dry ice is normally good for removing the sound deadning stuff
Really? I've always wanted an excuse to pick up some dry ice
So you just put the ice on top of it, wait, then peel it off?
Yeah, like OG said. You have a 12mm (or 14mm) bolt on the back of each caliper hiding a 5mm allen head bolt you use to adjust the piston. Tighten it up so the wheel doesn't spin anymore, then back it off 1/4 a turn and you'll be golden. You can do this without removing the tires and anything else. Just jack up the back of the car to wear you can reach that 12mm bolt head and 5mm allen bolt. You'll see what we mean when you look at it. It's an easy fix and should take 15mins.
ps- hopefully that 5mm allen bolt will thread in/out for you. Like Sleezer said, both of mine were seized and wouldn't budge. Sometimes you can get lucky if you open the bleeder valve it will take some pressure off but I had to buy both new rear calipers for my rusty Ohio P5.
Yeah... a common purchase for us unfortunately. I'm on my 3rd drivers side caliper and 2nd passenger side.
Phen, how the hell is your car still holding itself together? Don't tell me you don't have any holes in your floor...
I had holes in the floor 2 years ago. Nothing new there...
