Nice. I have an assemble short block already. Just have to rebuild the head and get a water pump, along with all the gaskets and miscellaneous stuff.
I bought all this to start the engine build:
[TABLE="width: 268"]
<tbody>[TR]
[TD]ARP Main Studs[/TD]
[/TR]
[TR]
[TD]ARP Head Studs[/TD]
[/TR]
[TR]
[TD]Wiseco Pistons .5mm overbore[/TD]
[/TR]
[TR]
[TD]Molnar Rods[/TD]
[/TR]
[TR]
[TD]Clevite bearing set[/TD]
[/TR]
[TR]
[TD]Cometic Head Gasket .051[/TD]
[/TR]
[TR]
[TD]Greddy Oil Plug[/TD]
[/TR]
[TR]
[TD]DW 65C Fuel Pump[/TD]
[/TR]
[TR]
[TD]Valve seal set[/TD]
[/TR]
[TR]
[TD]Coolant Temp Sensor Kit[/TD]
[/TR]
[TR]
[TD]Air Temp Sensor Kit[/TD]
[/TR]
[TR]
[TD]ID1000 injectors[/TD]
[/TR]
[TR]
[TD]ARP mani studs[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]OEM Mazda Oil pump[/TD]
[/TR]
[TR]
[TD]OEM Mazda Water pump[/TD]
[/TR]
[TR]
[TD]Timing belt kit[/TD]
[/TR]
[TR]
[TD]Fuel pump Strainer[/TD]
[/TR]
[TR]
[TD]AC/PS WP/ALT belts[/TD]
[/TR]
[TR]
[TD]OilFilters[/TD]
[/TR]
[TR]
[TD]OEM Mazda Gaskets[/TD]
[/TR]
[TR]
[TD]Oil cooler nut[/TD]
[/TR]
[TR]
[TD]Fuel pump filter basket[/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD]Supertech single spring titanium retainer kit[/TD]
[/TR]
[TR]
[TD]Steel valves Intake x8[/TD]
[/TR]
[TR]
[TD]Steel valves Exhaust x8[/TD]
[/TR]
[TR]
[TD]Steel valve guides[/TD]
[/TR]
</tbody>[/TABLE]
Pulling the motor as soon as it all arrives and starting the rebuild.
