what is the reason for a spun rod bearing ?
Spun bearing is when the bearing has overheated and fused itself to the crank journal and is spinning inside the rod. That will starve that journal of oil and will worsen over time. This is generally caused due to lack of oil.
yes you can do it with the motor in the car but you have to take the trans off so you can get to the 2 bolts that hold the windage tray on inside the transmission
Damn.. sounds serious..
Im Glad Before shipping my car here to Spain TBK Changed all OEM Rod Bearings I've putted when i did my engine, TBK replaced them with Clevite 77 ones..
I'll be right back have to step out for an hour or so. BTW i have a question about my thermostat, the Mazda Dealer From here Found me a thermostat for it looks a little different from the USA model, according to them they have to get it from Japan instead from USAi i'll post pictures and part number of it. i need you to help me find out if this is the same exact. cause looks different to my current one...
APC as in the Pepboys "racing" product line, or did you mean AWR? LOL...Do you have an upgraded oil pan?
If not you should order an APC baffled oil pan. It won't solve the oil problem but it will help.
do not go over 10 psi
its not the rod bolts that break, its the rods that actually snap....replacing the rod bolts really isn't going to do much for you and I wouldn't really recommend pulling apart your bottom end to do that unless you replace the rods and pistons as well....
