Maiello169
- Mazda, Protege, Speed
Thanks for the link, just what I needed !
Well a Cometic head gasket is priced over $100 on crossover, but you could talk to a local Napa or random parts store near you for a cheaper option. Surely you would need to replace the coolant and oil like you said, as well as the head studs since they need replaced every time you remove the head. Other than that, I'm really not sure and if you are having it done professionally then labor will probably be an arm and a leg.
I am having it done professionally but was one of his first customers so i get cut a substantial break on labor and parts are always at the price he would pay to order without markup. Are ARP head studs really worth the extra cross? Online the reviews are all mixed
Well that's good to hear. In that case I would have him diagnose the problem to be certain before ordering the parts. You should be fine with OEM mazda head bolts. I think people usually get the ARP bolts if they get any type of head work done (valve job, port, etc..)
just get a silencer and remove it when you want it loud and when you go on roadtrips bolt it back it for your girl. Allot less work than re doing the exhaust system.I got the exhaust back together... Got a quote on 3" back to the factory flange at the muffler so I can bolt up the Corksport with ease and switch between it and the Racing Beat OE muffler. Why you might ask... Because going on roadtrips with my girlfriend in a loud car would result in me being put in prison for murdering her because of her bitching...
Most people get the ARP studs because they are $80 cheaper than the OEM bolts. Definitely have the head checked and cleaned to make sure it is true. The valves on these cars are typically good for over 150k miles before they need a valve job. I have the $40 bolts from Rockauto and they have been fine for quite a while now.
Still soaking the axle and hubs with pb blaster ... Last resort is cutting axle and I have a nother one to put in with a new to me hub
^^^ what these two guys said.
Also what is the standard procedure when waxing a car with a cf hood? I thought i heard you can't wax cf....but I could be wrong. For reference I use meguires cleaning wax.
