*02 sensor circuit no activity
*System to lean, Bank 1
*VTC stuck closed
*Intake Manifold Tuning Valve Control Circuit Open Bank 1
*Coolant thermostat, coolant is below regulating temps.
Ok so here are my questions. Do you have the butterflys removed or just open all the way? if just open all the way, then put them back to how they should be and your idle should get better. Next, do you have a low temp thermostat? Have you ever replaced your thermostat?
when I had a very slight boost leak in the PVC hoses that go into the intake mani, it caused it to run like that, and ended up fouling up the spark plugs really fast... so check, and mine as well just change them while your at it, there cheap and that is what fixed mine along with fixing the boost leak.
and I assume there are no CEL codes? (edit: haha, woops, completely ignored all the codes you put up)
go to autozone and get them to read exactly what they are one I think is the bank too lean, and I am guess another is maybe a misfire in one or more cyl. but there must be one that is from the boost leak before you fixed it, but go to autozone and just get them to print out all the codes for you so it's more specific, but get some new plugs while your at it.. like I said, the boost leak making it run real lean(and I think when it's super rich like when it misfires, it will show up lean on the afr, even though it's super super rich) and then retardedly rich, it will kill your plugs
oh didn't even realize that those are what they all meant lol, woops, I just thought he was listing off possible things it could be, my head is somwhere else today...Quote Originally Posted by justanothermp5 View Post
*VTC stuck closed
I did notice a little oil around the gasket for the pcv valve. Do they sell that piece? And as far as spark plugs go, im also driving on a turbo with blown seals so im sure that's not helping
how would i check all my sensors around the throttle body? and the primary o2 sensor is new as of 3 months ago. and i was talking about the little grommet. also i replaced my pcv a while back with a milly s one. ive never heard of the msm pcv being used
