Ricktalife
- 2012 Subaru WRX
you HAVE to put the block to the left (facing the engine bay, intake side) of the check valve, or it will see only vacuum, and not boost. This means your WGA won't function AT ALL.
I would strongly recommend keeping the check valve, as your power brakes depend on vacuum, and without the check valve, unless your engine has the opportunity to rebuild vacuum in the brake booster after you are done boosting, you will have weaker brakes. This is bad on the street, and much worse at the track where fast transitions are common. and that doesn't even account for if you are heel-toeing. aside from that, I don't know how well the booster would physically tolerate having boost thrown at it, as it isn't designed for it, again, not recommended.
I plan on moving my vacuum block to the brake booster very soon. A tech at my work (not a turbo expert) suggested that having too many connections to the vacuum block might be a bad idea when hooking up to the brake booster. Any thoughts and experiences? On my vacuum block I have: boost gauge, ems, bpv, bov and ebc. Basically every aftermarket device that uses vacuum lol. In case you are wondering, my WGA is connected to the EBC and the EBC is connected to the vacuum block.
