We are going to start under the hood.
*Open hood
*Disconnect terminals on the battery
*Remove battery holder
*Remove battery tray
*Now unplug the mass air flow sensor
*Remove the mass air flow sensor and intake.
*At this point u should have access to the shifter cables .
*Use a pry bar to unclip both shifter cables from the mounting bracket.
*With the same pry bar remove both ends of the cables from the linkage
*Now if u follow the cables u can see where they are held against the rear of the engine block with a rubber gourmet. Pull it off from there
*Now the fun begins, get ur self a cutting wheel. I used my mac air one. I cut both cables right before where the silver insulation begins.
*Now ur cables are ready for removal
Time for removing interior pieces.
*First remove the glove box(I'm sure you all know how to do that)
*Time to remove the 10 mm bolt that holds the radio in place. u gain access to this bolt by removing the glove box.
*Unscrew ur shifter knob,remove ur cup holder by pulling it up wards, also remove ur shifter surrounding at this time. *Unplug the plug for the cigarette lighter and small bulb for the ash tray
*With that out , u can now unscrew the 2 Phillips bolts that hold the bottom of the middle counsel in place.(radio heater assembly)
*When the bolts are out u should be able to give it a pull foward and then u can unplug all the plugs from behind it and put it somewhere out of the way.
*Next step is to remove middle counsel (that's the one between ur seats. ) u have a total of 8 Phillips bolt holding it in place . 2 bolts on each side of the counsel, 2 by where u removed the 2 bolts from under the radio bazel,2 by the back of the shifter assembly and the last 2 inside the compartment were u rest ur elbow. Now u can pull the whole assembly out of the way.. now the fun begins..
* on both sides of the bottom of the dash u are going to,find some push clips that hold the floor carpet against the dash.2 on the driver side 1 on the passenger side
* Pull those out and pull the carpet back.
* with the carpet pull back u should see a shinny silver box under ur heater assembly. That s ur srs box( don't worry about ur airbags deploying u disconected the battery a while back)
*The little box is held down by 3, 10 mm bolts 2 of them are on the passenger side and the other bolt is on driver side, unbolt all 3 bolts and Unplug it and pull the the module out of the way pulling it toward the driver side.
*the harness itself is held down by 2 yellow clips, unclip then and pull the harness towards the passenger side.
*Time to get 2 the 2 hardest bolts u will ever have to remove lol..they are 10mm nut.
*Now reach in behind the lower area of the heater box and pull the insulation out of the way...its split in the middle so some will go to the driver side and some to the passenger side
*Now u should be able to see the 2 nuts that hold the cable base to the floor of the car.
*I was able to remove the 2 nuts with a long 10mm open end wrench. I was able to get them loose with the wrench and with the tip of my finger took them all the way off. Do the driver side nut from the driver side and the passenger side one from the passenger side.
*Once they are off then it's pretty much cake from there. Use the ply bar to ply the bracket off the studs themselves and it will be ready for removal..
*Disconnect ur cables from the shifter assembly itself and get ready to pull.
*Now have someone help you pull on the cables from inside the car while u carefully get the mounting bracket thru the bottom section of the dash. After the bracket is out just pull the rest of the cables thru..
For the installation do it in reverse order .. I sprayed my cables with wd40'just so that it would slide back in place easy.
And get those 2 10 mm nuts back in place and tighten them.. Is going to be a pain but it can be done.
