So I think Ultraracing does a great job on their marketing, but their diagrams are bit exaggerated. There are way more articulation than in reality, as they're trying to demonstrate a point to sell a product, If stock cars were that bad, steering/bumps/lane changes would catastrophic. Thinking about it logically this is my take on the differnce:
You said a STB will reduce lateral flexing at the show towers, I'm assuming you meant flexing between the shock top mounts (moving closer or further apart from each other) because its connecting only those two points, the connection of the lower control arms are not going to budge since there is a very hefty sub-frame already in place. With a hinged type STB you're taking any other movement out of the equation and simply ensuring that the strut mounts do no move further/closer to one another. With the Solid type, any movement/force is loaded onto the brace, which i'm not sure it can truly help with, not to mention that there are some downsides to its design due to the construction. Lets use one of ultraracing's own photos.
Notice that the bolt holes on the UR bar are slotted, they need to be that way since the bar doesn't move and installation is a too difficult with standard holes. With the hinged type, you can have circular holes because the end plates can be installed and the mid bar assembled after. this leads to a more true connection and transfer of forces. I don't feel like a nut has enough clamping forces to stop the sliding between the brace & chasis on the UR brace.
