How can the present be considered "late" when you posted this on Christmas Eve? I thought Christmas was Dec. 25th?
In any case, that oil catch can is unnecessary. The advertising copy at the JBR website is hilarious! It says, "During everyday engine operation, blow-by gases, as well as oil vapor from the engines rotating assembly, pass through the PCV valve and are routed into the intake for the engine to burn off. Before ever making it into the cylinders, some of that oil mist and other contaminates adhere to the backside of the hot intake valves. Over time a thick crust forms significantly reducing performance and potentially leading to a costly cleaning or repair. This is especially a problem for the 2.0 and 2.5L motor because, there's no fuel (Direct Injection) passing over the valves to wash and keep them clean. This is why an OCC is a must have for the Mazda SkyActiv motor."
The reason this is complete BS, is because all Skyactiv G engines come with a very effective oil separator mounted to the upper engine block. How do we know the OEM oil separator is effective? Because EPA emissions standards are quite strict and any significant amount of oil that was not caught by the OEM oil separator would cause the engine to fail the emissions tests.
We also know the sales pitch above is snake oil because we would have seen a rash of problems with crusty, leaky exhaust valves and plummeting MPG figures as these engines age if an oil catch can was necessary to prevent such problems. These are very sophisticated engines and there is no credible evidence the engineers failed to design an effective oil separator. In fact, even vehicles going to markets that don't need to meet EPA emissions get the same oil separator and PCV.
