Warning lights on dash won"t go off. 06 Mazda 6.
Muttlover
Mazda 6i, Mazda Protege 5
Occasionally, warning lights on dash stay on constantly after starting car. All of them. They wouldn't clear normally.
Found that by opening fuse panel under hood (beside battery) and pulling out each small fuse and reinserting corrected the problem for a few months. This is my second time since christmas so I tried spraying a bit of WD40 in each connector this time and then inserted the fuse.
Everything works again. Not sure if a bad connection or am I clearing a memory?
Thought I would explain what I did and maybe some expert can follow up on this in case others are having issues like this.
Whatever!
Muttlover
Lasted for a day. Most of the warning lights go off then during normal driving the brake warning light, ABS, traction icon and TCS OFF lights activated and won't shut off.
I pulled fuses and reinserted under hood as well as on panel by drivers door and everthing reset and was normal for about ten miles. They came back on.
Has anyone had this issue?
What needs to be done?
Help! Muttlover
I finally took unit to Mazda Dealer and after 2 trips car is fixed.
First trip to read code. Cost me $96.00. Code said C1165 and C1186. They tested resistance of Right Rear sensor and found at 10 ohms instead of 1.7 Kilohms.
They ordered right rear wheel sensor and called me 2 days later and set appointment for replacement.
2nd trip cost $216.74. Sensor cost $87.53 ( part # GJ6A-43-71YC SENSOR (R) ) and labour $107.10, $11.78 Enviro fee and $10.33 GST
All is well and not as expensive as I expected. The 2 trips were 180km each for total of 360km.
Hope this helps someone.
Muttlover
New Threads
