Unweld ab28f400
coucou50
protege
Any advice on how to unweld this beast ?
I went to a TV shop and they offered me to do it for 75 $ yayyy :s
Cheers.
Personally I'd use a desoldering wick or suction gun but if you wanna use a welder that would get rid of that chip real quick...
Get a tiny side snipper and cut all the pins off.
Desolder each pin individually then install the new chip.
Or just use the welder...
This is what you'll need...
Or this....
(use the welder... it's way funner)
Sorry english is not my first language. I meant desolder then. How do you remove the surface protective coating? Any solvant to use in particular ?
I have good news I thing I have found the adaptors to read eeprom through j-tag connector. No need to desolder the flash. I just had to look at ford stuff and bingo :)
