Turkey No More!!!!!!!
Congrats, glad to hear things worked out for u. hahaha mine will stay with gobbles for now until i want to take the time to figure out what i want to do.
so do you get turkey with CAI only? I am installing a SRI tomorrow, will I have the turkey too?
replacing the bpv with a bov wont kill the turkey?
why does it have to be a dual set up?
it doesn't HAVE to be a dual setup, you can relocate the MAF to run just a BOV but if you don't, the air need to recirculate through the BPV or the car will run like a wet horses turd
yes sir you will have yourself a turktastic MSP the car does it stock, its just that the plastic air box muffles the sound. what intake are you going to be using??
Weapon-r Secret Weapon Intake
Oh, i thought the sound was compressor surge created by the increase in air and that is why you need to do the dual set up to get rid of it.
So if I replace the OEM BPV with a forge BPV and add a Forge BOV, I wont have the turkey sound?
No. The sound is increased by the thin aluminum intakes. Has nothing to do with any increased air.
You need larger fittings on the intake and IC pipe to fully kill the surge with a single BPV. You can do it that way, or run the dual setup like you are saying there and either way will kill the surge.
Thanks for the advice
But if I dont add a blow off valve right away im not killin my car am I?
You aren't hurting the car by adding a CAI, the car comes with the turkey from Mazda. I personally love the turkey sound. My favorite thing about the car is making people on the sidewalks and drivers with their windows rolled down turn their head, and go "WTF?"
I know that the CAI or an SRI hurts the car and that it came like that but I mean am i hurting the car and the turbo if I wait to do the dual setup to get rid of the turkey since we all know turkey=compressor surge
when running the dual bpv/bov setup, in order to not hear turkey, you need a lager fitting from the hotpipe to the BPV (say 1") run the BPV line to the brake booster and just add the bov (say HKS) to coldpipe and the turkey will be gone correct?
Negative.. ur gonna recirculate like stock, u can leave the same vacumm source of the BPV/BOV and run ur HKS bov at the same time DUAL Set-up,then tap ur BB (brakebooster) line (At own risk) do this carefully or u will regret later (trust me). and run to HKS BOV. Car runs great this way no stalling,no ruff idle its great.
