Sweet! That was super fast. You guys are awesome haha
I think my sway bar is scheduled to come in on monday so maybe I wont be able to install until NEXT weekend (boo!) but Im sure Ill have questions for you guys during the process if I run into any issues (first time installing coilovers.. I did tokico struts and rb springs successfully minus all the rust, locked bolts, and cutting through endlinks hence the moog replacements in the front.. they actually are a TAD longer than stock so this is good news!)
I understand how the front struts camber, it is on the top where the strut mount attaches but I've been looking at the rear and I'm a bit confused about that camber.. hmm im not too sure what "the top hole on the bottom mount" means. I will try to look into that
as far as my rims they are ASA AR1 17" Black with machined lip... they were on my car when I bought it so I don't know much about them. I looked and found the +48 offset on the back of the rim but I don't have time to take it off right now or I'll be late for class. I did a quick search and found this chart
http://www.zinikwheels.com/specs.cfm?id=1277
so by process of elimination... BML, 17", +48, i think they have to be 17x7 ( AR17I72BML BML 17.0 7.0 5X114.3 n/a 73.00 48 )
I got new tires last year that are 215/45/17, kind of wishing I went with 40s but I suppose when they wear out Ill pick up a set of 18" enkeis with a lower profile tire on craigslist!
do you guys see any problems with fender rub (i kind of think I will need to roll them a little bit) and finally, do you think i will be able to join the Slammed Life with this setup haha
