So my friend who was supposed to be coming in town won't be here til tomorrow. What does that mean? It means I got down and dirty with some Miata drivetrain. I'm really happy with the progress I've made tonight. Made some unexpected discoveries, and got a lot done.
1. Got the transmission off! Finally!
Found that the front trans seal is bad. There's oil all over the bellhousing. Fortunately I've got an extra trans that's in good shape
Also found that the engine rear main seal is in surprisingly great condition. It looks about as new as my new one. Any better and it'd be still in the bag w/ a part number sticker on it...
So where's the oil all over the back of the engine / transmission coming from? Looks like it's still from where the CAS O-ring went long, long ago. Only problem is that after we (ie kcbhiw lol) installed it, we never cleaned the back of the engine. So is this new oil or old? It's kinda hard to tell. Since it's a $4 part from the dealer, I'm going to go pick one up / order it tomorrow. Rick Case Mazda's like 2 miles from my house
I'm also going to clean as much gunk as I can off of the engine so it should be pretty easy to tell when new stuff starts leaking.
2. Clutch
I don't really know what a clutch is supposed to look like, so I may be TOTALLY wrong, but it looks like it's got a really weird wear pattern. The inside is really worn out, while the outside barely has any marking.
And the flywheel:
Any input?
3. Tonight's intended suspension testing
As I posted earlier, I was going to look @ the suspension (fronts primarily, the rears checked out
) to try and cure the bottoming of the wheels in the wheel wells before the shocks hit the bump stop. While it's not a huge deal, the suspension isn't really doing what it's fully designed to that way. Plus, it's rubbing my fender liner. That's kind of annoying mid corner on course lol. A slightly longer bump stop SHOULD cure that. If it doesn't, next season I'll throw some 3mm spacers in there if it's bad enough that I think I need them.
I also never realized how bad I need to shave down my sway bar bushings. I can barely move the thing by hand w/o the endlinks attached. It's supposed to swing relatively freely. Any suggestions on how to do that effectively? Exacto knife? Sand paper? Other?
I think I'm missing a piece...
To get full suspension travel, I just took the spring off the shock so I could easily maneuver the tire through it's full range of travel.
In the process, I ended up taking a couple of really cool pictures that demonstrate just how much camber the unequal length double wishbone suspension on the Miata picks up through compression.
I can has camber?
For comparison on how the MacStrut and double wishbones (though there really isn't any comparison...) work differently through their range of motion:
HS Protege5 - Positive camber
STS2 Miata - Mo negative mo betta!
EDIT: HUUUGE thanks to Michael (autoxes) for his help on this. Having the extra set of hands was instrumental in this getting done in a relatively timely fashion without me totally losing my mind and all my tools lol. Thanks dude! (thumb)
