This is kind of a stupid question, but here goes.
I'm buying steel rims for my 02 p5. I would like to put 14 inch rims on the car to keep the cost down. Can I put any 5 bolt 14 inch steel rim on my car?
Thanks in advance.
No, the spacing on the holes will matter a lot. I think the correct spacing is 5x114 (mm) - 4.5 inches imperial. If you are going to a tire shop for some snow tires (which is what I assume you are doing) they will make sure they fit.
another steelies thread
for 14" look for,
bolt pattern:114,3 (4.5")
hub size: 67.1 mm
offset:+30 to +50
try it to make sure it clears the front calipers
look at my cardomain site page 5, it will show you what it looks like
I just had a thread about this, too. I think the only thing with 5x4.5/114 in 14's are going to be what monkeybone suggested. 94-99 eclipse/talon/sebring rims. I think most other chryslers with steelies should be the same size. Otherwise if you're looking for 15's I think camry's and accords might work. But I'm not for sure.
