Speed3 help and questions.
tabo
put a deposit down on an 07 speed3,
before i take delivery i want to know what kind issues, or problems are prominent on the speed3's.
any help will be appreciated as i did have a chub while taking it out on a test drive.
before i put a deposit down on an 07 speed3, i want to know what kind issues, or problems are prominent on the speed3's.
THAT would have been a smarter move... as it stands, just read many of the threads here to see what might potentially go wrong.
Here's a list of published TSB's for all mazda 3 models (includes non-speed as well as 2010+): http://www.finishlineperformance.com/store/pages.php?pageid=12
Note I said "published" because at least one bulletin mazda doesn't want public is a doozy.
On an '07 MS3 the VVT actuator and a smoking turbo are the main issues. The EGR valve will likely need cleaning or replacement sometime after 50,000 miles. The struts/shocks are weak and can go south from 30,000 miles on- if not sooner.
on an '07 ms3 the vvt actuator and a smoking turbo are the main issues. The egr valve will likely need cleaning or replacement sometime after 50,000 miles. The struts/shocks are weak and can go south from 30,000 miles on- if not sooner.
qft
which one would you say that is ?
I would recommend you try and find a later 08 model that has been properly sorted, 07 were prone to issues from all that I've read.
