I have a 2008 Mazda 5 Touring. I'm having a problem with parasitic battery drain, and it looks like it's the circuit with the ROOM fuse from when I measured the voltage across fuse. These two posts have a fix - disconnect the bluetooth unit. But my Mazda 5 has no bluetooth!
I think it's unlikely, but maybe Mazda installed a bluetooth unit, but it's non-connected to anything. So, I decided to remove the glove box and check to see.
This post says the glove box can be removed in seconds. I tried, unsuccessfully. The side arms come out fine, but the "little arm at the bottom that does the soft [close] you need to remove that little arm from a little ball that's on the glove box side." isn't working for me. I can't get the little arm off the ball. I tried pulling left and right, up and down, jiggling it, and it isn't moving. Below, see my photo with the little arm in the red box. What am I doing wrong?
When I do manage to remove the glove box, if I find there is no bluetooth unit to disconnect, what else should I look for for parasitic drain?
		 (Photo of glove box)
