Yeah.. I noticed that too... that was not staged.  I only noticed after I took the pics.
			I had a similar leak around that area. The dealership removed and reseal the timing cover. They also replaced the valve cover gasket and did the oil pan also, even though it wasn't leaking from there. All covered under warranty.
There's no way your AC compressor leaking oil or your freon should be totally gone from the pressurized and closed AC system - your AC wouldn't be cold at all! Like RuckinWestwood said, timing chain cover, valve cover, and oil pan seals are the most likely culprits!EDIT: Maybe my AC compressor is leaking oil?
That's unfortunate. Have you had a chance checking the previous suspected oil leak area between engine and transmission? I guess you can only take your CX-5 in and see what the dealer says. If they reluctant to do anything, may be you should show RuckinWestwood's post and presuade the service tech. We've seen people here having oil leak issues in these areas, timing chain cover, oil pan, valve cover, as Mazda uses sealer instead of traditional gasket.Unfortunately.... oil with dye was changed a few months back.
Did dealer put dye in your engine or transmission? It seems once the dye is gone, the leak shows up! I guess viprez586 said it correctly, your rear crankshaft seal is leaking.Looks like a small amount of oil residue on the original area as well from this thread... so two separate leaks I guess. I'll bring that one up again too.
If you have some ramps one can look into this area pretty well with a flashlight by just removing that small inspection cover in the middle. It is only fastened by one screw.
Ha, your dealer should learn the lesson from Mazda dealer used by RuckinWestwood, redo all the seals for all possible leak areas while they're there, timing chain cover, valve cover, and oil pan! They can charge all the work to Mazda anyway. (whistle)Mazda mechanic feels this latest leak is coming from the timing cover. They are tearing in to fix this morning.
And your dealer still insists there's no leak in the rear crankshaft seal like viprez586's case?
I will definitely be monitoring post repair as well.
EDIT: Still getting the road grime story... it was barely noticeable this time. Might try the talcum powder tip that was suggested to source exact location of where that area may be leaking.
Interesting tear down video.... of the chain replacement..... not my problem though
Yeah, I forgot valve cover and oil pan need to be off for timing chain cover re-sealing. Thanks for point it out!⋯ Additionally. The reason they replace the gaskets of the valve cover and re-seal the oil pan is because both of those components need to be removed in order to remove the timing cover. It's the proper repair procedure to address a leak from the timing cover, even if those 2 other components are leaking.
