SkyActiv Oil Analysis Thread
This report from January 2024 shows four samples on the CX-3. Went with Castrol, Pennzoil, Mobil 1, Valvoline
Which oil was sampled on 08/04/2019? It has too much calcium and not enough magnesium for these engines.
And your most recent oil sampled on 01/17/2024 looks like 5W-30 based on the viscosity. No way that was 0W-20 after 9,000 miles.
You are correct. I noticed that the top of the report says that most recent sample was from 5w30. Let me check my order history for the August 2019 sample. I usually order oil a few weeks ahead of time. On 3/6/2019 I ordered Zepro Eco Medalist 0w20... It was Zepro (https://www.amazon.com (commissions earned))! In an email to the lab contact I stated so to make sense of the higher moly figure.
That Idemitsu was the closest you could get to the Mazda OEM high-moly oil (also made by Idemitsu)
Note that most modern oils are already using advanced forms of moly that are 2-3x more effective per part than standard moly, and even better if they are also using boron, which is another friction modifier that works from colder temperatures. These modern oils are formulated such that everything is balanced, because some additives have effects on others in the bottle.
well she at least doesn't look like she is going to blow lol....I am happy that the fuel is low..I did a long 2500+ mile road trip running hard ie over 80 mph much of the way and over mountain passes running the rpms pretty high...on this oil change.
Some really good information here.
I checked my oil level the other day after the car sat overnight and while I don't have pictures from 1 year ago, it doesn't seem it has gone down much. I estimate between 0-10% in 4,000 miles. Engine has 8,000 miles on it now and uses 5W-30 Pennzoil Ultra Platinum (synthetic oil, alkylated naphthalene base).
In other news, my Oil Analyzers kit arrived so as soon as I pick up some oil from Walmart I can do my yearly change and get sample number 3 sent off.
I'm expecting my latest test result any day now. Just watched this today regarding the oil I've been using.
So why were they able to process yours in 5 days but I haven't heard anything about mine, which I sent in before yours. I hope it wasn't lost.
I would call them and ask. The first sample I sent in was destroyed during delivery. I didn't get a notice for that, it just showed up on my Horizon account. I had to call and ask what happened, and they sent me another kit. This time I sent it in a box with their prepaid label stuck on it.
