Hello Gentlemen.
I had posted this on the other board a very long time ago. But knowing how loyal people are to a single board I've come to find out that several are not looking into this. So here it is:
THE MATRIX: 3rd Generation Proto's
Mazda Protege5 fitment guide
215/40/17; 215/35/18
7.0" +45 and higher
7.5" +48 and higher
205/40/17
7.0" +42 and higher; Barely making it
7.5" +48 or higher, the +45 still worries me with this width on a 205.
Mazda Protege Sedan
Can run 2 to 3 mm less offset than the Wagon. Appears to have a little more room under the fender. As we've got no problems with wheelguuruu's 19's at all.
BEWARE OF THE PASSENGER SIDE. IT will be the first to rub. hehe. Not as much negative adjustment on that side, even with camber bolts. Based on left hand drive. hehe.
Hope this helps everyone. Please feel free to call us as we will be stocking the real good ones, quality, appearance, weight, perfect fitment. Plus you'll get your forum/club deal and the sanctity of mind that the fitment has my blessing.
Be weary of the "local tire shop" as many have not done real time fitments prior to your consultation. Not even the manufacturers who create the fitment guide for the dealers have test fitted everything. It's based on patterns with fitments in the industry. Unfortunately, our cars veer off that line just slightly but enough to be very annoying and bad when you just bought wheels that you were told fit only to have them rub.
We are a tuning shop and therefore specialize in certain performance oriented vehicles. Therefore do multiple fitments on the same vehicles with different wheels and so forth. We weigh them loaded and unloaded, tires and wheels. It's some good info to base your decisions on.
Thanks, Rishie
PLEASE READ IT SLOW AND TAKE NOTES. THIS IS A NO bulls*** POST. ALL OF THE INFO AND STIPULATIONS ARE INDICATED.
7.0" +45 and higher
7.5" +48 and higher
205/40/17
Mazda Protege Sedan
Thanks, Rishie
